macr0w
macr0w's Avatar
08.28.2007, 10:52 AM
I'm telling ya, its related to the motor rotation direction. You need to reverse the throttle servo, and set it up from there.
I guess I will give it a shot. I got nothing to loose but time.
You mean to reverse it on the transmitter right?
macr0w
macr0w's Avatar
08.28.2007, 11:51 AM
Well, I tried to reverse the throttle on the radio and I just got the same thing in reverse. I tried to adjust things from there but I got the same result.
I put it back in the "norm" mode.
08.28.2007, 03:07 PM
Did you try my suggestion? Flipping diffs and reversing throttle wont make a blind bit of difference in my eyes- all it will achieve is losing the brake function when going from forward to reverse, as was previously stated. Try another radio (less hi-tech), and if that doesnt fix it, then it must be an esc problem.
