mjderstine
mjderstine's Avatar
03.04.2009, 11:52 AM
that looks pretty awesome man. what kinda speed were you getting outta that one?
can you take a pic of what it looks like around the tranny and diff area? its hard to see whats there with all the elecs in there.
crazyjr
crazyjr's Avatar
03.04.2009, 01:11 PM
I will as soon as i can, All he really did was drill 4 holes into the skid and cut a hole for the diff gear (he used an ofna diff/51 tooth plastic diff gear) there is a slight offset for motor clearance. My current gearing is 19 pinion with the 51 spur and 1/8 buggy diffs (stock)
here is the setup according to Brian G's speed program
6s
Differential Ratio: 3.3076923076923075
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 51
Pinion Tooth Count: 19
Total Voltage: 22.2
Motor KV: 1183
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0
Spur/Pinion Ratio: 2.68 : 1
Total Ratio: 8.87854 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 26262.6 RPM
Vehicle Speed: 51.04 mph (81.99 km/h)
Effective KV Value: 1183
and 4s
Other Ratio: 1
Total Voltage: 14.8
Motor KV: 1183
Motor coil Ω: 0
Total Motor Speed: 17508.4 RPM
Vehicle Speed: 34.03 mph (54.66 km/h)
I know i never run the motor even close to the true potential but it never got hot or faltered. The MGM is giving me some problems, Got to send it back in, but i am running a quark 125 (unmodded) and will see how it runs on 4 and 5s.
5s should be intresting
Other Ratio: 1
Total Voltage: 18.5
Motor KV: 1183
Motor coil Ω: 0
Total Motor Speed: 21885.5 RPM
Vehicle Speed: 42.53 mph (68.32 km/h)
I will get the pics, of the diff setup, as soon as i can
mjderstine
mjderstine's Avatar
03.04.2009, 01:25 PM
awesome man.
so he took two center diff mounts, put them on the center plate, and ran it like that? sounds VERY simple to me, and easy to do.
is the main benefit of the center diff to help preserve the driveline?
how much does it help over the stock slipper gear that is already there?
I have also modified my driveline with revo driveshafts instead of kyosho universals or the stock dog bones. do you know if there are any diff outputs that would accept the traxxas revo yokes?
crazyjr
crazyjr's Avatar
03.04.2009, 06:28 PM
the main reason for the center diff is to split the power Front and rear, if you get a lot of power you can set the center to offload more or less to the front depending on traction available.I'm sure there is a bit of protection, but its not the main thing
