Compro 22418 -
09.20.2007, 12:10 PM
Hey guys,
I got a Compro 22418 in last week and finally got to play around with it a bit. I don't know if what I'm experiencing is trouble or not.
I've noticed that when ever I program it with the radio, it heats up. Not super hot, but as hot as it gets when I'm running it. Is it supposed to heat up like that during programming? My 16016 doesn't heat up like that when programming.
Another thing I've experienced is that the 22418 just flips out whenever I try to use the auto programming mode. I program it, then go back into programming mode and choose the fifth option in the first category, which should put me into the auto programming mode, but the controller just sits there beeping with the pattern that indicates that the data in the eprom is corrupted.
The third thing I've experienced is that when you try to reduced the throttle delay to the minimum (for some stupid wheelie action), the controller just shuts down or drastically reduced output.
Has anyone else experienced any of these things?
I was also wondering if the 22418 can be programmed through the radio connection without the "cable" that Mike is out of stock on.
Thanks
