t-maxxracer32
t-maxxracer32's Avatar
10.01.2007, 08:36 PM
well we dont have to worry about that no more! i found one that will work! YESSSS!
i ended up not needing any of the resistors! what a waste of 4 dollars!
anyways its working awsome and i can go however i want without worrying about it shutting off!
thanks for all your help!
10.01.2007, 09:40 PM
You may not "need" the resistors, but adding them to the 3.3v and/or 5v line might make the 12v more stable and less likely to dip under heavy loads. A little testing with a voltmeter should show if it helps or not. But if it works as-is, great!
t-maxxracer32
10.01.2007, 10:50 PM
well i only plan on charging 1/18 scale batts (ie max charge rate is 2.1 amps...) lol so i think i should be fine right?
10.01.2007, 11:57 PM
lol, yeah, I should think so. 6 cells @ 2.1A only requires ~2A of power supply current. It's when you start charging large packs (4s/12 cells+) at high current (5A+) that the charger starts pulling lots of 12v current.
