squeeforever
squeeforever's Avatar
10.13.2007, 08:24 PM
Learn something new every day...
10.13.2007, 08:55 PM
Yeah, I figured out the idler thing when I first tried to figure gear ratios. Had some very strange numbers before I realized the idlers purpose!!
Hickoryhead
RC Wanna BE
Hickoryhead's Avatar
10.13.2007, 09:31 PM
My thinking of all this is if you can gain power and torque you might not need such a big motor like my 1950 1800kv to power a Maxx size car. You might be able to use a 1920 size or similar one. Meaning having a lower transmission or slipperntial powered by a smaller motor. That would cover the motor size worry and give you a lower ceter of gravity. I am not sure if it would work but I will try to see if I can get one built. I understand the gear issue to. It will take some playing around to find the ratio that will change.
Finnster—I don’t want to draw attention to myself or sound like I am bragging but I feel I do “think” differently than other people. I failed certain math classes in HS because the teachers demanded I show my work. They could not understand how I came to solutions yet I had the answers. I took some pre tests for college math and I tested out of most of the classes. I know how to solve the problems but I go about it other ways. I take that route with alot of problems in my life. Drives my wife nuts. My brain does make up for it in other areas. I have a picture perfect memory and other talents. No offence taken. I can take a good ribbing.
NECESSITY IS THE MOTHER OF INVENTION
Emaxx Tranny slipper modification (Strobe like)
http://www.rc-monster.com/forum/showthread.php?t=9341
10.13.2007, 10:45 PM
Go ahead Hichory, do something different! This is what this hobby is all about. Us here on these forums are doing the newest and greatest in RC right now. The first converted nitro to brushless was years back and the mfgs are getting ready to bring it to the masses. We here are the 1/2 of one percent of rc car nuts who are actually raising the bar. This is new territory, more brushless products are coming out every day, and we will be the ones to make them work, in ways never considered before.
I threw out my ideas on the direct to diff outrunner conversion a few months back and I had plenty of nay-sayers. I did it anyway and it works, and works well. Maybe the higher end motors and their greater effecientcy will pave the way to more common HV systems. If these motors can work well at 45k rpm then lets use them at that. Sure it is twice the speed of a BB nitro mill, but lets see how it works.
Smaller motor, more voltage, less weight and lower gearing. Taking the torque load off the motor and spinning it faster may work well. No feigao is going to be able to do this, but the high end motors may. I have 4 different aveox motors on the way and a few kontronic escs too. Going to start with 7s and go up.
I would like to see what the smaller 1930-40 lehners and the 1506-09 neus can do with alot of voltage and some lower gearing. Batteries are getting smaller and lighter, so higher cell counts are getting more and more useable. 4k 30c lipos could be enough to power a 1/8 rc when used at 8-10s.
squeeforever
10.13.2007, 11:32 PM
Running a 1920 isn't that unheard off. Sjcrss was running a 1920 in his VERY heft Maxx monster he use to have.
