Shadow350Z
Shadow350Z's Avatar
07.05.2005, 04:21 PM
cleaning my Maxx right now...
discovered that i cracked my rear Bulks!!!
will the integy aluminum bulks be ok?
r they good?
the super duty type II
  Send a message via AIM to Shadow350Z
gcurtis2121
07.05.2005, 05:05 PM
I've got the Integy Super Duty bulks and they're great. I know they probably weight a little more than the stock ones or even some of the other aluminum ones, but to me the strength is worth it. The bulks take a lot of punishment and I didn't want to have a weak link there.
Shadow350Z
Shadow350Z's Avatar
07.05.2005, 06:54 PM
for now im jus gon get the rear ones
since thats the only thing i cracked
squeeforever
squeeforever's Avatar
07.05.2005, 08:48 PM
the proline servo saver is pretty good. i think you have to make a little modification to the stock chassis. i would recommend just getting a heavy duty kimbrough servo saver and a bluebird 630mg. thats exactly what i have and im very happy with it.
Shadow350Z
Shadow350Z's Avatar
07.07.2005, 03:13 AM
wuts the advantages of CVD over the stock telescoping ones that came with the maxx?
Dafni
Dafni's Avatar
07.07.2005, 05:26 AM
They wont get twisted into Brezels. (But they can snap in a bad crash)
Depending on your driving style, wheels, and BL, the stockers might last quite a bit. But proper shafts is a good investment when going BL.
Shadow350Z
Shadow350Z's Avatar
07.07.2005, 11:32 AM
my center shafts are about ti get twisted
and my rear ones are already twisted
wuts the cheapest CVD for the Maxx???
and also for the center oens
braaap11889
07.07.2005, 11:39 AM
Don't go the cheap route man you will just end up spending twice as much before you get some nice parts. Go UE off the start. I know you can't order over the internet, so i guess you are stuck with the lower quality stuff for now. MIP is second to UE so get MIP cvds. When I first started upgrading my maxx I broke arms and bulks left and right well to say the least i upgraded with integy and had some problems. Try your best to go for the good parts from the start and you won't regret it. I don't know how much you bash or beat on your truck but for me daily driving with integy always had disasters. Integy is super duty bulkheads are actually weaker than the stock traxxas shock towers or atleast thats what I found out when i broke the shock tower mounts on the bulk and not the shock tower.
Shadow350Z
Shadow350Z's Avatar
07.07.2005, 11:43 AM
this one for the CVD right?
http://www2.towerhobbies.com/cgi-bin...&I=LXDXN7&P=ML
how bout these?
http://www2.towerhobbies.com/cgi-bin...?&I=LXHLK6&P=7
how bout the center ones?
braaap11889
07.07.2005, 11:49 AM
both will work get the top ones though.
braaap11889
07.07.2005, 11:51 AM
heres the center kit http://www2.towerhobbies.com/cgi-bin...&I=LXDXN8&P=ML
Shadow350Z
Shadow350Z's Avatar
how bout the center shafts for the E-maxx?
the ones for the 2.5maxx i cant use cuz they not the same lenght
Shadow350Z
Shadow350Z's Avatar
07.13.2005, 03:55 PM
hey braaaap
but when i went to the towerhobbies site it says on the comment thing
"COMMENTS: The CVD takes the place of the original half shafts.
This Will Not Work with the E-Maxx because it uses 6mm output
shafts and the T-Maxx uses 5mm output shafts."
Serum
Serum's Avatar
07.13.2005, 05:31 PM
MIP doesn't make a shiny set for the center of the e-maxx.. Weird by true..
Shadow350Z
Shadow350Z's Avatar
07.13.2005, 05:43 PM
My telescope shafts are starting twist
especially the center ones and the rear ones
Serum does MIP make CVD for the center of E-maxx?
