Originally Posted by mxracer
what gearing u running , and wat r the temps like ..
his truck is a inspiration !!
for a normal technical track i use 13/48 or 14/48. the esc temps are from 102-112, motor temps are from 122-155, battery temps sre from 75-99(the lower numbers are from a 20 minute test on asphalt running from min. to max. throttle with 14/48 gearing, the higher are from wot oval racing for about 10 minutes running 18/48)
