Originally Posted by neweuser
Of course, I have not tried the Flight Powers, which could be why. The reason is runtime. I cannot find a flight power pack that goes to 8000mah
Sylvester used to run 4S 8000mah MaxAmps in his 1950 powered LSP. He since switched to 3700mah 4S 25C FlightPowers and only lost 10 minutes in runtime (30min down to 20). So, it seems that per amp-hour, the Maxamps packs provide 3.75 minutes, while the FlightPowers provide 5.4 minutes. Not only that, but he said the overall performance of the FlightPower packs was significantly better than the MaxAmps packs.
MaxAmps packs are pretty good packs, but their packs lack a lot of qualities that I switched to LiPo to obtain. For me, I see LiPo as a lightweight pack that can deliver high currents. With MaxAmps packs, it seems that you have to get an excessively large capacity pack in order to get a pack that can supply high currents. This, obviously, takes away from the lightweight quality. My FlightPower 4500mah Evo30's are rated to 135Amps continuous, and I truly believe that they are capable of providing that kind of current. The MaxAmps 8000's I previously had were rated to 160Amps if they were true to 20C. Most people say they are close to a 15C pack. Even if I was generous and gave 17C, the pack falls to 136Amps, nearly identical to the FlightPower Packs I currently use. However, the 8k's weigh 365g per pack, while the FlightPower packs weigh 252g per pack. Between two packs, thats over a 200g loss in weight. (Each of the packs I referred to, be it MaxAmps or FlightPower, were those of 2S configuration).
I'm not trying to bag on MaxAmps or anything, but they just aren't cost efficient (i.e., they are priced a bit too high if you ask me). Each of my FlightPower packs costs me $125 from Tower. Tower currently has a spend $149, get $20 off promotion going on. Not only that, but since I'm a member of their Super Saver's Club or whatever, I get free shipping on orders over $150. Therefore, I add, say, a Novak Smart Stop, and my order reaches $150, and then drops to $130 as a result of the promotion.
With MaxAmps, a 8000mah pack costs $155 (not including the cost of adding a plug and other stuff), plus ~$7-10 shipping. Thats ~$165, and all you get is a pack. On the Tower order, it costs ~$130 and you get a pack and a corresponding voltage cutoff for it.
Now, if you are concerned about runtime. Take 8 x 3.75 and get 30 minutes. Take 4.5 x 5.4 and get ~25 minutes.
Thats my personal view of it. I'm running a top of the line motor, why not buy top of the line batteries? Specially when they are cheaper.
