11.01.2007, 02:00 PM
I'd also like to know what your MM settings are too actually ^_^ im actually putting mine together right now
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
Neu 2s 5000 Mah 30c Batteries
M11 DSSS
Airtronics 358
Socal
11.01.2007, 02:53 PM
Please post the settings you guys are having success with. I ran the MM on a 6 pole Plettenberg with no cogging issue what so ever. My settings are:
Brake/reverse type: Proportional w/o reverse
Brake amount: 40%
Start power: Low
Motor timing: Normal
NeuMaxx
11.01.2007, 04:46 PM
I found that a linear throttle curve was a problem because I have a "heavy trigger" finger. IIRC at the 30% point hold with the left mouse button and pull down so that the results is a soomth curve upwards.
11.01.2007, 05:33 PM
I don't have the MM in front of me (and it's at home, I'm at school), but I think the settings are:
-High start power
-30% punch control
-timing I'm not sure of, but I think I have it at medium
-linear throttle curve
-60% brake
NeuMaxx
11.01.2007, 09:12 PM
The cogging was helped tremendously by making the throttle curve exponential. My settings were:
brake 30%
punch 80%
start pwr high
motor timing low
11.01.2007, 09:21 PM
Yes, I've heard that is a problem with the Emaxx trans. A smooth can motor would allow a smaller pinion, but I don't know how small.
11.01.2007, 10:35 PM
One thing I noticed that might be causing all the cogging is the stregth of the magnet on some motors in conjuction with the stator.
11.01.2007, 10:46 PM
I was talking to Joe down at castle today, and he mentioned this as well. The gearing is sensitive for consistent loaded down startups.
BMW M Power!
11.01.2007, 10:52 PM
Well, this is one thing I notice with the Tekno conversion. It utilizes the stock Revo clutch which allows the motor to rev up before actually having any load on it at all, which would reduce cogging quite significantly, if I'm correct.
11.02.2007, 12:08 AM
But, given the torque of BL, wouldn't that put considerable stress on the driveline? I suppose you could dial in some slip to fix that though...
