11.12.2007, 11:23 PM
Originally Posted by rchippie View Post
Would a different mamba system be better or is the 5700 system the better choice ?. also do i need a bore reducer ?.
You may want to ask briang, he is using a mm 4600 on his crt.5, but he runs 3s. I am not very impressed with the mm motors. I have tested most everything including the vxl system from traxxas against my mm esc and feigao 12s (3000kv). I have not found a better sytem yet, for 3s lipo that is. I found the mm motors to heat up very quickly, but my gearing was higher than yours so there was more load on the motor. I would give the mm 5700 setup a try and if you do not like it sell the motor and buy a feigai L can, or some other type of motor. It is best to experiment to find the best combo you like, I can only give my experience, which is limited to 3s and higher. I have maybe ran 3 systems on 2s and was dissatisfied with the performance. I even run a twin traxxas titan 12t motor wild dagger on 3s lipo! Those brushed motors can handle some voltage!
rchippie
rchippie's Avatar
11.12.2007, 11:26 PM
Thank you I just ordered my motor mount & bore reducer.
REAL MEN RUN BRUSHLESS
11.12.2007, 11:43 PM
No problem, it is hard to give advice cause everyone's driving style and intended use is different. I like really fast trucks and bash in grass and on the road. Wheelies are a requirement for me, as is top speed. I have not broken much, except maxx diffs! My driving skill has improved much since I started rc 2 years ago.
rchippie
rchippie's Avatar
11.13.2007, 08:58 PM
I was at work today & got to thinking. Would the traxxas venolin system be any good in my crt.5 Or is the MM a better choice ?.
11.13.2007, 09:02 PM
On 2s the velineon will be slower than the mm. Plus the velineon esc does not have much (if any) programability. I have owned both and consider the mm esc to be very superior.
rchippie
rchippie's Avatar
11.13.2007, 09:07 PM
thank's again . i just saw the venolin motor is only 3500 kv. I'll just get the 570 MM system from my friend's store.
rchippie
rchippie's Avatar
11.15.2007, 01:08 PM
i just talked with brian g & he suggested not to use the mm motor but to use a feigo s motor. He said a 7s with a 15t pinion would be good for around 35 with the kit tires. He also said if i wanted to use truck tires that a 8s with a 14t pinion would be good. He also said these motors would not get as hot as the mm motors because they have a little more torque. So im probably gonig to get a 7s motor. what does everyone think ?.
11.15.2007, 01:17 PM
Well if you do not want the mm motor, the feigao s can is a better choice. I have a stampede with a 12s on 3s lipo and it has run better than any other small motor I have tried. I have pitted it against the mm motors, the velineon motor and a few others. If you look I posted a thread that shows the internals of the mm motors versus the vxl motor. Both are smaller than the feigao s can.
I have a slightly used (2 runs) 7s motor here, If you want it send me a pm. Nothing wrong with it, just too high kv for me as I am going to 4s and higher systems.
rchippie
rchippie's Avatar
11.15.2007, 02:44 PM
Ygpm
rchippie
rchippie's Avatar
11.19.2007, 12:23 AM
I would like to post a couple of pics of my crt.5 conversion so far, but i dont know how. Can i email them to some one to post for me ?.
11.19.2007, 12:29 AM
Do you have a photobucket acct?
Sign up and you can upload your photos to photobucket and then jut copy the img code and paste it in a post. The pics will show when you preview the post or submit it. It is also nice to be able to access them from any pc too!
rchippie
rchippie's Avatar
11.19.2007, 12:33 AM
No i dont have a account there even if i did i would'nt know how to use it. Im not very computer smart.
ssspconcepts
ssspconcepts's Avatar
11.19.2007, 01:16 AM
You can also sign up at Picasa....its free and easy.
http://picasa.google.com/
BlackedOutREVO
11.19.2007, 01:27 AM
Check your pms bro
BlackedOutREVO
11.19.2007, 01:45 AM
There you go
Nice start!
