BP-Revo
BMW M Power!
BP-Revo's Avatar
11.21.2007, 05:05 PM
Ok, here we go. Final renderings. I'll probably double check all measurements, but they should be good to go...
Fronts:
Rears:
Let me know what ya guys think.
Again, specs are 10mm extension (so 20mm total width increase). I also added more shock mounting positions. One on each side of the current 2, for a total of 4. They can be used on the right or left side (universal). Weight is ~30g per arm.
cemetery gates
11.21.2007, 05:16 PM
Nice! now what about driveshafts?
Bye
DrKnow65
DrKnow65's Avatar
11.21.2007, 06:58 PM
These ones (post #16) look excellent, it looked like there were a few scissor points in the last ones you posted. It looks like you may have a bit of a sheer problem with the front a-arm on these. I circled a thin piece at the top right of the shock mount from the first photo that I think could sheer under a hard forward impact (and seperate from all of your otherwise excellent triangulation) :)
Sorry I coudn't make the circle red, but for some reason I couldn't get it out of grey scale....
BP-Revo
BMW M Power!
BP-Revo's Avatar
11.22.2007, 02:49 AM
Ok, I thickened up that section a bit. Its about 70% thicker now. Should be fine.
DrKnow65
DrKnow65's Avatar
11.22.2007, 10:24 AM
Good work BP-Revo, nice job on the arms.
mwry13
mwry13's Avatar
11.22.2007, 03:01 PM
What kind of files are they? if there something common, go on and send the file to me, ill run it threw Solidworks Cosmos for a analysis if ya want
Kyosho 7.5 Kanai 3
Neu 1515 1y/f
Neu 2s 5000 Mah 30c Batteries
M11 DSSS
Airtronics 358
Socal
BlackedOutREVO
12.03.2007, 04:51 PM
BP
Are these going to be real? Any price estimate on them?
cemetery gates
12.03.2007, 07:34 PM
Originally Posted by BlackedOutREVO View Post
BP
I talked to Mike(rc-monster) and he has plans for 3/8'' extended arms. He told me to wait for them to come out.....
Bye
BlackedOutREVO
12.03.2007, 07:45 PM
Bye
Nice!
Thanks for the info
ren
ren's Avatar
12.07.2007, 01:26 AM
What about making wheel hub extenders like they do for 1/8 buggies and trucks?
http://www.amainhobbies.com/product_...ducts_id/12748
It seems this would be an easy fix and would eliminate needing longer driveshafts and arms, but I don't know how easy it would be to machine.
MetalMan
MetalMan's Avatar
12.07.2007, 03:04 AM
That is a valid idea, although it's not always so practical - by pushing the wheel out further, it effectively allows the force from the wheel to have more leverage against the bearings. This causes premature bearing wear, and then extra replacement bearings. But by keeping the wheel in the same spot relative to the bearings and a wider arm, the result is a wider truck without any abnormal bearing wear.
