Serum
Serum's Avatar
12.01.2007, 11:11 AM
mine dont seem to have any slop.
can you use your calipers and measure the inner diameter of the holes on the ofna and the outer diameter of the revo shafts? Perhaps they revised the design, but i can't imagine that they have.
nl12
nl12's Avatar
12.01.2007, 11:32 AM
adaptor id .237 shaft od .235
which 17mm adaptors do you guys suggest?
What did yours measure serum?
riceman
RC-Monster Gold
riceman's Avatar
12.01.2007, 01:21 PM
Another option if you want red.
From what I've heard these actually fit better than the Maximizer aluminum ones. I haven't run these myself but I believe these are the adapters that Tekno is running on their prototype Revo.
dirt101
dirt101's Avatar
12.01.2007, 02:12 PM
I thought revos use a 5mm axle, it says those are for a 6mm
I dont have any calipers, sry im just going by feel.
riceman
RC-Monster Gold
riceman's Avatar
12.01.2007, 02:17 PM
Revo, Tmaxx and MGT = 6mm axles
12.01.2007, 03:19 PM
Those look alright. FWIW, the integy 23mm hexes are troublesome- when the wheel nut is fully tightened it can cause the hex to rub/bind against the axle bearing, which obviously isnt a good thing.
crazyjr
crazyjr's Avatar
12.02.2007, 11:20 AM
Originally Posted by Serum View Post
they are only attached to the shaft with a through pin, and the hole for the shaft in the ofna hub is larger than the actual diameter of the wheelshaft. That's what makes them sloppy.
I am running the ofna 17mm Tmaxx adapters right now and no slop and no problems, with losi wheels and tires (1/2" positive offset)
drkros3
12.22.2007, 04:29 AM
hey i have heard that the integy 23mm hexs are bad. can any one tell me why they are bad. cause they are the only red ones i found in 23mm and i cant use 17mm hexs any more cause i have 2 sets of tires in 23mm.
thanks!
drkros3
12.22.2007, 04:30 AM
hahaha nvm i guess i should of read a few post above lol. my bad.
t-maxxracer32
t-maxxracer32's Avatar
12.22.2007, 04:55 AM
what the hell is FWIW
bdebde
That's All Folks!
bdebde's Avatar
12.22.2007, 05:20 AM
for what it's worth
Serum
Serum's Avatar
12.22.2007, 07:10 AM
www.urbandictionary.com and there is no need to curse...
