bluesilver
12.08.2007, 08:54 PM
Thanks for all you help.
I have set it to Racs mode and it has solved all the problems.
Running nice and cool and right up to full throttle without any dramas.
Thanks again.
Appreciated.
Finnster
KillaHurtz
Finnster's Avatar
12.08.2007, 09:29 PM
NP, but you may want to get a separate LVC in the future. You can run the lipos lower than you mean to fairly easy, and they are an expensive investment to ruin. Too bad the on board one didn't work a bit better for you.
david lamontagn
12.08.2007, 10:33 PM
In race mode, you don't have any LVC i think
But in "batterie type", just set it to 4 li-po, and the controler will set the LVC automatically.
bluesilver
12.09.2007, 04:02 AM
If I set it to 4 Lipo won't it cut out at 12V?
I am only running 3s
I take it then that in race mode it will basically keep on going untill the battery in dead flat. ( no 9v cut out)?
lilian
12.09.2007, 09:05 AM
I think you should put the esc in "reduce rpm" mode: safer for you battery and no problems for full throttle.
ncalenda
Need for Speed
ncalenda's Avatar
12.09.2007, 10:08 PM
I tried today to set the battery type higher then that actually battery type, and it doesn't work. So, if you have 4S you have to set it to 4s.
If you set it to Race Mode, I would like to know what happens once the LVC kicks in? Does it rev up?
  Send a message via AIM to ncalenda
Finnster
KillaHurtz
Finnster's Avatar
12.10.2007, 11:43 AM
If you set the cutoff higher, then the motor will cutout even sooner. You can set it to lower # of cells, but at that point why bother? Running a 3S lipo down to ~6v (2S setting) is bad.
As said, race mode disables all safeties. No LVC, no motor power reductions, nothing. Its the "its in your hands, be careful not to break it" setting.
You want some sort of safeties, if the LVC @ 3S cuts out on you to early, you may need better batteries to a more flexible external LVC.
Serum
Serum's Avatar
12.10.2007, 12:18 PM
Too bad the maxamps packs are not delivering the power you need; you might contact Jam on this forum to help you out.
Have you got an eagletree that can monitor your packs voltage?
the better the battery, the more it will be able to hold the voltage under a high load.
The race-mode might seem to help you out, but it's not a solution. You might be able to drive it, but it's killing the lifetime of your pack.
Like Finnster said; if you run the LVC at 4S on 3S pack, it works the other way around; it's better to put it to 2S than to run it in race mode. Both are not adviced though. They pack you are using is not up the task, perhaps Jason from maxamps can help you out.
ncalenda
Need for Speed
ncalenda's Avatar
12.10.2007, 02:19 PM
good info!!
what batteries do you think will not dip in voltage like this?
Serum
Serum's Avatar
12.10.2007, 02:31 PM
Perhaps there is just a bad cell in that pack, i don't know. It might help if the pack is fully charged. What is the outside temp? the colder it gets, the lower the voltage of the packs under load.
Enerland cells have the tendency to keep their voltage very well.
Polyquest, Hyperion, flightpower are a few that come to mind.
hemi123
12.11.2007, 06:28 PM
i dont think its the battery it might help to get a pc link for the controller. that way you can see how many amps your pulling.
