I need 20x30cm 3mm carbon fibre for the extended lower deck which is how i've decided to mount the cells.
I've decided to go that way to lower the c of g and to get the weight distribution further back.(although further from the centre line)
I've found a piece in the UK for £75 for good quality all carbon laminate.If you know of any cheaper please let me know.
I also found graphite plate at Graphite store.com which was only around $50 but shipping was over $100 from the US.
I'm going to make a prototype in ally in the mean time before machining the carbon.
Mike, i haven't recieved the motor and controller yet which you had sent direct from BK, i was wondering if you could check if it was sent yet.i know you've been waiting for 9920s aswell.I'll e-mail you about that anyway with the details.I'm also after some maximizer diff cups for the LST.Thanks.
I am chasing down a couple BK orders actually, and should have them all squared away by tomorrow(they have been a little backed up apparently, as I have been waiting over a month now!).
I will look into the CF for you, and will pick up the maximizer lst diff cups for you as well.
now that is AWSOME!!! i have 2 LST's and wouldnt mind converting one to electric. how much would u charge for a chassis??? (if u wanna make another one) i would be highly interested in one. that is amazeing work man. nice job
Funny you should say that, Dabid. I thought about the very same. I daydreamed about doing an LST with selfmade alu plates. X braces would cure the taco effect!
