RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
11.15.2011, 02:02 PM
Dual servos is accomplished with linkage - the bellcrank setup is largely the same as stock so it is no problem to use dual servos(although dual servos is not necessary - 1 good servo is the ideal setup).
cmac
cmac's Avatar
11.21.2011, 08:54 PM
Thanks Mike, as soon as I can get my hands on a UE servo saver I will install and I'm sure it will fix the problem. On to my next build. I just got my pair of Hot bodies 43t 8028 ring gears and that completes my parts list. I can now start my build. I will not do another complete build thread, but I will post pictures when I can.
cmac
cmac's Avatar
11.24.2011, 08:48 AM
Well I just bought a gen 4 UE servo saver and can't wait to install it
George16
Supermaxx
George16's Avatar
11.24.2011, 08:53 AM
Congrats, those are to come by. How much did you pay for it if you don't mind me asking?
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
cmac
cmac's Avatar
11.24.2011, 10:47 AM
$95.00 US. I also got the spring pack from UE $12.00 on the way.
http://www.ebay.com/itm/160688343760...84.m1439.l2649
cmac
cmac's Avatar
12.04.2011, 03:47 PM
I have not heard back from UE on my spring package, is this common procedure? They took my money though. This is the first time I have ordered from them directly.
George16
Supermaxx
George16's Avatar
12.04.2011, 04:00 PM
Yup, that's common. There is no more email or anything after Sam left the place and let Robin do everything. You'll get it though.
Revo with OS .18TZ
cmac
cmac's Avatar
12.04.2011, 08:40 PM
Thanks that's good to know.
cmac
cmac's Avatar
12.10.2011, 12:54 PM
Ok, I just got the time to swap out the steering linkage for the UE (gen 4) servo saver,and took the truck out for a spin. I still have the severe pull to the right. I now don't think it's the saver that is the problem. I am now thinking it's the 300k diff oil and locked slipper. At first I tried to run the truck with two servos, but I am now going to give in and just go with one. I know I'm stubborn, but when all the senior members in here keep saying just use one.........( I can here you guys saying I told you so). I just think all the torque is forcing the truck to the right under full acceleration. I'm really glad that I got the UE servo saver it just really looks great and you can tell what craftsmanship when into the design. So, guys what diff oil should I try to use? Remember I still want to be able to pop the front wheels up off the ground at will.
Thanks,
Mike.
coolhandcountry
coolhandcountry's Avatar
12.10.2011, 01:17 PM
Since you are running a thick diff oil, have you thought about the tires.
Is one side growing more then another?
Does it pull to one side at a low speed or just high speed?
Peace!
Country
Help support the
Rc-Monster
Buy here
Unfortunately
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Unfortunately - 12.10.2011, 01:54 PM
Unfortunately a lot of this hobby is trial and error. Even with the best advice from some of the most experienced hobbiests you have to try different things to find what will work best for your vehicle and your style of driving. With your severe pull under acceleration I would try going on the low end of things and work your way up. Losen your slipper just a tad, and put some low weight diff oil in your diffs and see if it all goes away. Even though the advice given to check your steering linkage did not resolve your problem it did give you a better look into exactly how well or not so well your steering was working. The UE Gen4 servo saver is the best one ever made for sure, and you are lucky to have one for your truck. It sounds like you have worked your way pretty much through all of the possible problems that your steering could have been giving you.
So I would go back to what I started telling you a while back. Your getting torque steer from your drivetrain because of the power your truck has in it. It could be a fault in your setup (sticky bearing, of bad toe adjustment, Etc), but I really do believe that you just have to play with your diffs until you get it where you want it to be. Are your tires taped and balanced? Are you using beadlock rims or just gluing your tires? If you have your tires taped and you are not seeing any ballooning, than that leaves your drivetrain itself as your culprit.
I think I remember asking you to try disconnecting your front driveshaft and just running it with rear drive and see what happens. Then try running it with just front wheel drive and see how that works out. That will give you a good idea how the front and rear wheel drive works independently so you can figure out if further adjustment is needed to run them together.
SUPERMAXX YOUR LIFE.
cmac
cmac's Avatar
12.10.2011, 02:50 PM
No it happens the moment I pull on the throttle. I have the tires double gorilla taped so they don't balloon at all.
coolhandcountry
12.10.2011, 03:07 PM
Can you switch sides with tires for a test run and see what happens?
Peace!
Country
Help support the
Rc-Monster
Buy here
cmac
cmac's Avatar
12.10.2011, 08:03 PM
I'm willing to give anything a try.
cmac
cmac's Avatar
12.11.2011, 10:25 AM
I don't know why I didn't think of this but my tires are directional. I can't swap them for the other side.
