Anything is possible
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Anything is possible - 12.11.2011, 11:17 AM
Originally Posted by cmac View Post
I don't know why I didn't think of this but my tires are directional. I can't swap them for the other side.
Well anything is possible, but honestly unless one tire is totally different from the rest I doubt that it would make much of a change for your particular problem. And even though the tread is directional you can still try swapping them around for a test. Even so as long as they are all the same size, and the weights do not differ more than an ounce or two I would find it hard to believe that it would change your driving experience to swap them around. The only way tires would affect steering would be if they were different sizes like they do with some oval track racing. They put small diameter tires on the left side to make the vehicle naturally want to turn left making it easier to steer through the turns.
What you have been describing as your torque steer issue would not be affected by the tires unless one side is balooning drastically. Alignment maybe, but this seems more like a diff issue where one side is receiving more power (rotation) than the other. You have to try whatever comes to mind after you do a little knowledge based elimination. Eliminate what you know for sure is not your problem, and make a list of what you do suspect, and then test that theory one by one until you have tried everything that you can think of, or the problem disapears.
Steering issues under power can only be caused by a few things. The servo is always the first place to look. Second would be the steering linkages to make sure that there is no slack or binding of any kind. If it operates smoothly by hand than it should do the same under servo power as long as you have the right servo for your setup. Next is the drivetrain itself. Closely examine each axle for any unusual binding due to a bad bearing or improper installation. The diffs are next in the line. Diff slipage is an individual descresion and you have to set yours up to match your expectations, but you still have to make sure that they are smooth as silk and have no binding what so ever. The last thing in the drive line is the transimission or center diff including whatever slipper you might be using. Make sure that everything is operating smoothly and easily as it should. I cannot think of anything else that will effect your vehicle in the way that you have described.
SUPERMAXX YOUR LIFE.
coolhandcountry
coolhandcountry's Avatar
12.11.2011, 01:33 PM
Have you noticed if it dog tracks any?
I looked back but no video to see.
Maybe something out of line in rear of truck as well.
Just things to look for that is simple.
Peace!
Country
Help support the
Rc-Monster
Buy here
cmac
cmac's Avatar
12.12.2011, 07:26 AM
I'm not sure what "dog tracking" is. Yes I still have not had the chance to get the video camera out to film this running.
coolhandcountry
12.12.2011, 08:49 PM
Dog tracking is where the rear is out of whack.
The back of the truck runs out further on one side then the other.
It can cause all kinds of weird steering issues.
Peace!
Country
Help support the
Rc-Monster
Buy here
cmac
cmac's Avatar
12.13.2011, 01:28 PM
I have a question not related to my metal maxx. I am putting together my stock brushless emaxx (3908) and I am going to use dog bones for center drive shafts does anyone know what length the front and rear shafts are? I am using the stock plastic chassis and the stock transmission.
12.14.2011, 12:49 PM
I don't know the actual lengths, but if you are looking for bones to use that will definitely fit:
http://204.186.93.64/NewE-Maxx-CenterDogBone.htm
Saves a job- Mike can custom make dogbones too, though he'd need the dimensions before he started, so...
cmac
cmac's Avatar
12.14.2011, 11:25 PM
Thanks Neil,
I found out that I needed a 60mm pin to pin for the front, and a 120mm pin to pin for the rear. I have both on the way. I already bought them before you posted, but as always thanks again.....
Mike.
mothman
12.15.2011, 12:31 AM
Thanks Neil,
Mike.
Did you get the 120mm from kershaw design as well? I have been trying to find 120mm pin to pin dogbone for quite some time..
cmac
cmac's Avatar
12.15.2011, 07:40 AM
No I actually got a Ofna 40710 120mm dogbone.
http://www.ofna.com/parts.php?start=3600
mothman
12.15.2011, 11:53 AM
I was told that Ofna measures their dogbones according to the overall length, not pin-to-pin. I might be wrong. Please let me know once you get the parts.
And as for the link on Kershaw Design, the dogbone is not 120mm.. it is only 114mm, according to Dan, the owner.
cmac
cmac's Avatar
12.17.2011, 03:35 PM
Yes, you are correct the 120mm measurement is end to end not pin to pin. It turns out that even with that I still had to grind the ends on my bench grinder and now the back drive shaft has just the perfect amount of play.
K1RC
12.30.2011, 03:36 PM
I just read this build from start to finish after, cmac, you referred me and I'm glad you did! It looks fantastic and has definitely motivated me to make my own Maxx
Keep up the good work
04.05.2012, 04:16 AM
Aren't you using a 3908 tranny? As neil said above, they don't break, so nobody has made stronger gears for them.
You will break diffs, driveshafts or strip wheel hexes before you break a 3908 tranny, no matter how hard you bash.
cmac
cmac's Avatar
12.30.2011, 05:00 PM
Thanks so much. It was a learning process, but really fun. Good luck on your build, and let me know if you have questions. I don't know everything by a long shot,but I will be happy to help when I can.
Mike.
K1RC
12.31.2011, 05:41 AM
Yeah I've learnt a lot by reading builds like yours so hopefully my build should run quite smooth, much appreciated
