Originally Posted by redshift
(metallurgy) Animal, vegetable, or mineral oil, such as fish oil, cottonseed oil, or lard, used in quenching baths for carbon and alloy steels; removes heat from the steel more slowly and uniformly than water.
As long as it has a high flashpoint, I don't know how much it matters. I think normally it's between 40 and 90 weight standard oil. But they do sell dedicated products if you want to be particular.
It is critical that you shove the part into the oil in one quick motion, or else you may end up with one side harder than the other.
Looking great man!
thanks for the tips Redshift.
so this morn i went to Jiffylube and they gave me some used conventional motor oil. it was pure black. went to cnc shop, fired up the torch, got the gears cherry red, and quenched them. it was sweet!! smoke and bubbling like crazy. they turned out great. my gears look just like the ones from RCM now. black instead of the pretty silver like they were. but like Kaz my drive shaft doesnt fit in the reamed area of the gear now. need to dremel out a bit and it will be fine.
also, today i left all my aluminum hubs and the integy disc brakes with my CNC. i am having the hubs customized so that the disc brakes mount up with a "factory like" fit. after the hubs are done, everything thats left to do on the kit i can do in my garage.
i am going to try to get everything else done on the truck while the hubs are at the CNC. should have some pics of mounted motor, esc, and servos soon.
