scarletboa
scarletboa's Avatar
04.09.2010, 12:27 AM
Hyperthetical question:
If you knew that Castle would replace your 6mm rotors regardless ( their error/ omission on the original listing ), would more of you be inclinded to have a go at grinding the shafts down from 6mm > 5mm ( all thats required is a vice/lathe & a dremel/file afterall, and it has been done by a few guys already with great success )?
Given the choice/dilemma I'd grind those shafts baby- 4 months is a long time to sit around whining about something you could fix is less than an hour with basic hand tools & little chance of messing it up ( little by little, check with calipers and/ or the pinion until it fits snuggly ).
i am very prone to screwing stuff up when it comes to making my own mods on stuff, especially motors, batteries, electronics, etc.
when i was still trying to use KB motors (6mm shaft) on my attempted BL savage conversion, i ground the shafts down to 5mm myself. all i did was secure the motor with my left hand on a table and the dremel in my right hand. i hooked it up to my esc and my radio system and used throttle trim to get the motor spinning at a fairly low speed. i just kept grinding the shaft as evenly as i could until a standard 5mm pinion fit snugly. this little task is pretty hard to screw up and long as you try to grind evenly and check the size often.
Urgeoner
Urgeoner's Avatar
04.07.2010, 07:58 PM
Anyone here think that the 1520 would be better in the muggy? it is more efficient with power than the 1717?
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.07.2010, 08:25 PM
It'll have no less power and fit better than the 1717
Semi Pro
Semi Pro's Avatar
04.07.2010, 10:24 PM
alot of guys use the 1515 2.5d in the muggy im sure a much more powerfull 1520 would be enuff
but if your going to go big why not go all the way and use the 1717
Urgeoner
Urgeoner's Avatar
04.08.2010, 05:35 PM
Not sure. I guess after reading that it will need more voltage (at least 5s-6s) than the 1520 to perform well.. Or did I read wrong?
Whatever though I'll keep it anyway. I just have so much on my plate atm like bills and crap that affording a descent 6s battery will have to wait.
RuthlessLST
04.08.2010, 07:36 PM
If anyone wants to sell a 1717 they have been sitting on... shoot me a PM.
bruce750i
bruce750i's Avatar
04.08.2010, 12:20 PM
After getting my gear ratio more reasonable with Mike's new stealth 68t mod .8 plastic slipperential spur and 15t pinion. I ran my 1717 13.5lb savage last night on Terra-pins for 18min of speed runs up to 45-50mph, wheelies, and jumps on pavement. It only used up 4.5ah at 23v.(avg. of 250mah/min) The 1717 was a sizzling 110*f. My 1520 in a 12lb rc8t used 357mah/min. Not really Apples to Apples but it's something. I made a graph of my findings.
Kcaz25
Kcaz25's Avatar
Thumbs up 04.08.2010, 01:51 PM
The graph is GENIOUS!! You must have spent countless minutes, nah! years designing the software and carefully planing the mathmatics to calculate something so precise and profound!!
bruce750i
bruce750i's Avatar
04.08.2010, 02:58 PM
Yes, as you can clearly see the fun of the 1717 peaks a litter higher than the 1520.
Edit:It was a 65t not a 68t as stated above.
Urgeoner
Urgeoner's Avatar
04.08.2010, 05:28 PM
lmao Bruce
Great graph!
A 5mm Rotor update
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
A 5mm Rotor update - 04.13.2010, 12:22 PM
Email exchanged with Castle Rep Greg;
Jeff,
The production schedule was pushed back, and now we are expecting the new rotors sometime in early May. We apologize for the delay, I have confirmed your order and you will get yours as soon as we can ship them out.
If you have any further questions, please feel free to e-mail us or call the Tech Support line.
Greg Wright
Product Specialist
235 S. Kansas Ave
Olathe, KS 66061
913-390-6939 ext. 138
greg@castlecreations.com
On 4/8/2010 12:53 PM, Jeff wrote:
Hi,
I'm on the list to be shipped the 5mm Rotor for the 1717 motor, Last I spoke to another Rep was a few weeks ago and the gentleman said in a couple weeks they/you would have them in. Is there any news on this ?
I'm anxiously waiting to run this big beast in my Losi XXL !
Thank You,
Jeff /Bondonutz
RuthlessLST
04.13.2010, 12:33 PM
Are you kidding me!! I built a truck around this motor and now it’s just sitting collecting dust.
So now my question is...If you turn the shaft down to use the motors and burn it up, can we get replacement parts NOW or are we stuck waiting months or years?
That raises another question...Since most of these motors have been sitting in boxes using up the warranties how is Castle Creations going to handle a future warranty issue?
Sorry but this is really ticking me off!!!
Thomas Porfert
Thomas Porfert's Avatar
04.13.2010, 03:11 PM
Gents,
I have in my hands a limited number of 1717 rotors with the 5mm shaft. I currently have 6 people on the list. Those 6 gents will be getting e-mails in a few minutes. If you do not receive an e-mail, it means I do not have you on the list. If you need one, please shoot me an e-mail at thomas (at) castle creations (dot) com. Sorry for the delay, but hopefully we have enough right now to cover everyone. Thanks for your patience and understanding!
Thomas Porfert
Castle Tech Support
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
04.13.2010, 03:59 PM
Originally Posted by Thomas Porfert View Post
Gents,
Thomas Porfert
Castle Tech Support
Return email with addy confirmation sent !!!!!!!
Thank You Tomas
Thomas Porfert
04.13.2010, 04:12 PM
It's out the door already. Thanks!
Thomas Porfert
Castle Tech Support
