brushlessboy16
brushlessboy16's Avatar
03.16.2009, 10:05 PM
It will not, the bearin race on the genisis spur gear is made for a 10mm ID bearing- i tried.
Just about any 8th scale spur gear will work on it with minor mods.
93firebird
03.16.2009, 10:18 PM
check out these links. From what I see the bearings are the same part number used on the front/rear and center diff of the genesis as well as the matrix center diff. That bearing is part number g73914 which is 8x16x5 in size.
http://www.cenracingdirect.com/images/GST77.htm
http://www.cenracingdirect.com/images/MatrixC1Buggy.htm
also note that the back plate part number gs060 found on the matrix center diff is the same as the plate used on the front/rear diff of the genesis, which uses the same housing as the center diff.
brushlessboy16
03.29.2009, 10:43 PM
I think its time for an update. Purchased and received a secondhand Kyosho Motor mount. I the bearing holes line up fine but the upper post was .08'' too tall. a hacksaw and grinder fixed this.(avoids me buying Kyosho CD mounts). Also purchased my R1 body from jhautz- one of a dying breed- That should be here monday or tuesday. And Just now I placed a rather large order from Amain...
Wheels, tires, batts, center CVD's, Screw kit, Shock oil, and some other odds and ends.
Today I also rebuilt the entire front end with a Gene Hickerson Suspension setup
1 x AKA Racing Premium CA Tire Glue (AKA38001) = $7.69
1 x Pactra Outlaw Black Spray Paint (3oz) (PACRC250) = $5.39
1 x CEN Racing Out Drive (TR) (2) (CEGMX301) = $12.75
1 x Pactra Grape Pearl Spray Paint (3oz) (PACRC292) = $5.39
1 x CEN Racing Cross Pin, Must use with MX212 (CEGMX213) = $2.39
1 x AKA Racing City Block 1/8 Truggy Tires (Medium) (2) (AKA14102M) = $27.49
1 x Hot Bodies Rear Center Universal Shaft (Lightning Series) (HBSC8061) = $14.99
1 x Pactra Sprint White Spray Paint (3oz) (PACRC251) = $5.39
1 x JConcepts Rulux 1/8th Truck Wheel Standard Offset Half-ups (Yellow) (4) (JCI3311Y) = $18.99
1 x Hot Bodies Universal Center Shaft (130mm) (Lightning Series) (HBSC8169) = $16.99
1 x Pactra Fluorescent Race Yellow Spray Paint (PACRC284) = $5.39
2 x SMC 2S1P Hard Case Li-Poly Battery w/Dean's Connector 24C (7.4V/4100mAh) (SUM4124LD) = $129.98
1 x CEN Racing 53mm Wing Mount Post (2) (CEGMX094) = $6.79
1 x AKA Racing I-Beam 1/8 Truggy Tires (Medium) (2) (AKA14101M) = $27.49
1 x Team Losi Silicone Shock Oil (50wt) (2oz) (LOSA5227) = $3.69
1 x Team Losi Silicone Shock Oil (60wt) (2oz) (LOSA5228) = $3.69
3 x OFNA 8x10x0.3 mm shim kit (10) (OFN10413) = $3.87
1 x Tony's Screws CEN Racing Matrix TR Screw Kit (TSK-MATRIXTR) = $41.99
03.29.2009, 11:12 PM
Looks good.
brushlessboy16
03.29.2009, 11:14 PM
Thanks
03.29.2009, 11:16 PM
When is your amain order due in?
brushlessboy16
03.29.2009, 11:17 PM
No clue, I put the order in a half hour ago, better before saturday
03.29.2009, 11:21 PM
you should get it around thursday. Amain has stupid fast shipping
brushlessboy16
03.30.2009, 03:14 PM
You were right on that note The order shipped already
brushlessboy16
03.29.2009, 11:25 PM
Hopefully, cus then i need to find time to install all the stuff! Then work all the bugs out by Saturday morning. Gotta be at the track by 9:30.
trev3813
Dsm needed
trev3813's Avatar
03.30.2009, 03:57 PM
o0o Niceee
brushlessboy16
03.30.2009, 09:28 PM
Thanks, cant wait to get this thing together. this week is going to go by soo slow.
brushlessboy16
03.31.2009, 06:55 AM
bit of a downer here.. For the last 2 weeks i have been talking about racing and getting my truck together... My mother ordered my stuff from amain for me- and I tell her "i need to have the stuff by thurday at the latest, get USPS priority.." She gets UPS ground because it was the cheapest(even tho i was paying) so my parts wont be here till monday... there goes opening day. wooptie doo. :(
03.31.2009, 07:52 AM
brushlessboy16
03.31.2009, 08:26 AM
Thanks... Kind of bummed about this though.
Tags
cen matrix
