jzemaxx
03.17.2008, 09:46 AM
Hey Aqwut, why not go with the dual 1527's and a dual-belt system? If I refer to the gear on the center differential or whatever it drives as the spur gear, and the gear on the motor shaft as the pinion gear, then why not have a very similar layout, except with places to mount two motors, instead of one, like the E-maxx motorplate, and have one "pinion" be farther out than the other by mounting the second motor farther forward by the width of one belt to avoid the belts hitting. Then have dual "spurs" (one right in front of the other,) hook up some belts, and you're ready to go. I hope this will give you an idea or two.
If he's looking for 10000 watts then twin 1527's will do the job.
03.17.2008, 09:50 AM
Yeah, hopefully he'll understand what I was trying to say in that post.
aqwut
Brushless Heavy Weight....
aqwut's Avatar
03.17.2008, 11:13 AM
Awesome.. I didn't think the 1521's could put out that kind of power... it's good to know... Lutach..
I may just go with twin 1527s then... thanks guys... I appreciate all the input...
2x MGM 24160, 2x 8S 30C 5000mAh, 2x 1521-1Y (1250Kv), all 10AWG wires.. and 6mm Bullet connectors for batteries & motors..
should give me... 8800+ Watts of continuous power on demand... guess that's good.... should make my truck about 20-21Lbs...
The Power of BRUSHLESS!!!!!
1HP (electric) = 746 Watts.
Everything is brushless!!
jzemaxx
03.20.2008, 09:09 PM
Did you decide on a motor yet and controller for sure?? I am going to get my 1521 hooked up tomm hopefully and see how it does on the MMT if I get my motor clamps. I hope its got enough juice to push my truck to 70mph or so. Right now the biggest problem is finding tires to do big mph runs on.
lutach
lutach's Avatar
03.20.2008, 09:28 PM
HPI Phatlines.
jzemaxx
03.20.2008, 10:52 PM
HPI Phatlines.
I'm using them now.....had two blow outs so far....always split on the edge of the tire close to the rim
lutach
lutach's Avatar
03.20.2008, 11:14 PM
Did you buy the premounted ones? That's the same problem I had with mine. My next set will be done with some tape on the tires and that should help them a little.
jzemaxx
03.21.2008, 10:27 AM
Yes pre-mounted ones......
They have been good till right under a shade under 70mph. Running around 65-67mph which is what the truck runs consistently. Let me know how the taping works out....
jzemaxx
05.07.2008, 09:03 PM
Aqwut have you gotten your 1527's?? Are you still doing the twin setup on motors?
Serpent S811-E Tekin
Revo 3.3 BL- 1515 1Y
Mugen MBX6 NEU/MMM
Mugen MBX6-T NEU/MMM
Losi LST2.0 MT NEU/MMM
Losi 8T RTR 2.0 NEU/MMM
Losi 8T 2.0 NEU/MMM
Losi 8B-E 2.0 NEU/MMM
05.07.2008, 09:10 PM
Aqwut, I had an idea. Instead of dual 1527's, why not something like dual 1915's or something?
aqwut
aqwut's Avatar
05.08.2008, 12:34 AM
no Jze... haven't heard anything from Mike yet... Maybe he's pissed off at me for selling batteries on the forums?.. I dunno.. or maybe Neu has some shipping problems....
I'm in need of this motor...
hey Jze.. after seeing what that 1521 can do, I might just stick to single 1527, but it Mike takes too long with the 1527.. I'll just buy me a 3080 or something.... race season is already starting this weekend coming up....
But Lehner has my 2280 motor, and decided to cover it under warranty.. so I don't have to pay anything but shipping....
The only motor I have to put on the GST are the KB45.. I might have to do this, since I don't have any other big motors at the moment..
BP.. I like the 1527s.. more power!!!
Did you buy that 3080 of ebay Jze..?
jzemaxx
05.08.2008, 12:47 AM
I went with 2 more 1527's and a 2215 coming. I was talking to Neu today, thinking about trying something like you had attempted. I am going to see if I can still fit twin 1527's on 12S....so about like you had said....around 9000 watts...lol. This would be on the buggy, problem is I really haven't figured out how to mount the motors. The batteries are now taken care of though......
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
05.08.2008, 10:04 AM
Any thoughts?
jzemaxx
05.08.2008, 10:48 AM
Hard to say. The 1527 will run 4000 watts pretty easily according to Neu, plus you can run the rpms much higher. The 1915's are rated 3000 watts and RPM's are limited. The 1915 runs a larger diameter rotor, but the 1527 rotor is LONG.
Mugen MBX6 NEU/MMM
Losi 8T 2.0 NEU/MMM
aqwut
aqwut's Avatar
05.08.2008, 11:44 AM
I just can't wait for the motors to come in... I only have the GST and Firehammer Left to work on.... 9000+ Watts is my goal as well.. I want to drag my bike around..
