FG101C
05.13.2008, 02:18 AM
Will a 4s1p 20C Polyquest (Enerland) pack be ok with the MMM, Neu 1515 1/Y/F in a Losi 8-T? Do we HAVE to run a 25C pack?
glassdoctor
TEAM FUSION
glassdoctor's Avatar
05.13.2008, 02:26 AM
Just to add here:
One of Monsters was killed with a Neu (Enerland god-like cells, lol) pack, so how do we link that to the "blame it on maxamps" answer?
Thing is... the ones that died have simply shut off. No smoke, no heat, no cogging, nothing. And it's happening too quickly imo, to be a blown caps. And it's not a blown FET either. (no cogging, no smoke, no burnt smell)
These are dead in the brain, not the power board. Maybe there is some weird battery-induced thing going on here... but right now it's ALL wild speculation.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
jhautz
jhautz's Avatar
05.13.2008, 03:49 AM
I posted this over there, but it adds to this conversation just as well.
Something else I dont get while reading the Mamba Monster page at the CC site.
How can they rate this for 18 cel NiMH or 6 cell lipo? I dont know of any NiMH cell that can deliver bursts over 125A and maitain 75A continuous.
Here are the specs copied and pasted from the CC site.
Retail Price: Mamba Monster ESC: $199.00
Cells: 18 NiCad/NiMH 6s LiPo
Continuous: More than you can handle!
Resistance: 0.0003 ohms per phase
Brake: Proportional with adjustable curve
Reversible: Yes - with lockout
Low Voltage Cutoff: Programmable
Size: ESC: 2.2" x 1.9" x 1.4"
Weight w/wires: ESC: TBD
Connector Type: 6.5mm bullet
If it was the batteries killing these things they certainly couldnt rate it for NiMH and NiCD cells then. There is no way they can hold the voltage of even crappy lipos.
to make it...
or break it...
Silent...But Deadly
DRIFT_BUGGY
DRIFT_BUGGY's Avatar
05.13.2008, 04:09 AM
Good point
Losi 8ight
MMM V1 w/1.20
Airtronics MX3 2.4Ghz
TP 5S 5000mah
Neu 2.5D/F
luvsrc
RC-MONSTER BRUSHLESS FANATIC
luvsrc's Avatar
05.13.2008, 07:17 AM
You guys dont need to worry on what other websites are saying, Castle creations and Maxamps are two businesses that are really flourishing and expanding and the more they get popular, the MORE INTRIGUES they are going to get in many other forms for other people wants to pull them down it is called "CRAB MENTALITY"
Brushless Jammin Truggy on NEU 1515 2.5 D on Monster mamba max with maxamps 5000mah 6s Lipo
Gorillamaxx Revo CF version on Mamba maxx ESC with NEU 1515 1Y on Maxamps 4s 8000mah Lipo
sikeston34m
sikeston34m's Avatar
05.13.2008, 07:52 AM
This is BS.
The Quality of the Battery affects how much power the ESC is able to feed the motor. That's all.
The firmware of the ESC knows what to do with voltage drops. That's the job of the LVC function.
I aggree with the NIMH use statement.
Let's say the Lipo packs are only capable of giving up 40 amps Max. Let's say these are Generic and way over rated.
But let's put this and the MMM with a very big motor and gear the setup for 100mph.
A setup like this would overload the amp capability of the batteries.
The ESC would not run the motor the way it should perform because it would be on the lvc all the time.
Heat is a tattle tale sign of what component is being pushed too hard.
The Packs would quickly get hot and probably puff some cells, if not all the cells.
The ESC doesn't care what batteries are used, as long as the voltage is within specs. The ESC is going to deliver whatever amperage is available for it to work with.
lutach
lutach's Avatar
05.13.2008, 09:32 AM
Could that be why I got an e-mail from MaxAmps about a free 3yr/300 warranty?
05.13.2008, 10:07 AM
So, MA packs are killing MMMs. Hmmm, sounds a bit odd. Like someone said, they don't seem to popping caps or FETs, just something on the controller board.
I agree with others: What works on the MM should work on the MMM, electrically speaking. If the appropriate cells for the application are selected, things should be fine. Yeah, excessive current draw should trip the LVC and/or overheat/puff the cells quicker.
Could it be something related to the AC ripple on the power line not being filtered enough for the BEC's liking?
Could it be something slightly wrong with the FET switching where both legs of the H-bridge are switched on at the same time for like a micro second? That would short out the pack for a VERY brief time, yet not damage the FETs because of the short time. True, this is unlikely, but this whole thing sounds odd.
Even if this is true; with any new release, there's bound to be issues to iron out. Even in extended testing, it's very difficult to test every possible scenario and setup out there. Before people start pointing fingers, we should hear direct for MA or CC to see what exactly is going on with the failures.
05.13.2008, 10:10 AM
Good point Brain,
I have a feeling that CC will wait to test/inspect the faulty units before posting any info. It would just be specualtion anyway, so it really does not help anything.
skellyo
skellyo's Avatar
05.13.2008, 10:19 AM
I'd like them to address why they are telling folks that MA batteries are suddenly inadequate to use when they were fine in the same setups with a MM. Granted, the first post I made was second hand information from the poster on rctech, we really deserve an explanation either way. With the information posted on public forums, inaccurate news/information travels fast so I'm hoping Patrick will peek in this thread and put it to rest.
05.13.2008, 10:27 AM
It's probably just a safety blanket statement until more details can be found. No sense in people blowing more packs until the issue can be pin-pointed.
It's kinda like if you smell something burning in your kitchen and you aren't cooking anything. You unplug/unhook everything to eliminate all causes. Then, you look into what's going on. Once you find that small piece of bread jammed in the toaster, you plug everything back in. OK, bad analogy, but you get the idea.
Squeak, squish!
Squeak, squish! - 05.13.2008, 10:32 AM
Ah, yes, maxmaps are but a small piece of blackened bread in the kitchen that is rc!
No makey sense!
skellyo
skellyo's Avatar
05.13.2008, 10:35 AM
Or, it's possible it was a single phone call where the context of the conversation was much different than that portrayed here online. Seeing as how we haven't seen any notice from Castle to discontinue the use of MA packs, I'd think this was probably a miscommunication somewhere. But, it still would be nice to see someone from Castle specifically say, "No, that's not what we said/meant", or, "Yes, don't use MA packs for reason XYZ".
DickyT
Being the information was posted by a person that is neither a rep of CC or MA and neither company has come forward it is nothing but hearsay. Patrick posted yesterday in another thread here that only 4 MMM's were called in as dead, and 2 of those were running TrueRC packs that never got warm.
also they only say the "CC support guy", I'd like to know who he talked to, it's not like Castle is a huge company in number of people.
It just does not sit right. Someone form either company would have said something publically by now.
skellyo
skellyo's Avatar
05.13.2008, 10:37 AM
On another note....
I'm just glad you're in south FL Dicky. I don't want to catch any of your bad juju on my MMM's.
