brushlessboy16
brushlessboy16's Avatar
07.30.2008, 02:25 PM
gah! u should have gotten pics....
Byte
08.05.2008, 04:32 PM
Originally Posted by dpb318 View Post
according to the calculator i should be going about 30 mph, so maybe ill get more than 15 min, although my truck is a lot heavier than a buggy did i enter the stuff into the calculator correctly?
i used plexiglass for the battery cover and i didnt bend it. the sides aren't attached to each other
Where can I find that calculator?
Nice Savvy btw!
dpb318
08.05.2008, 04:40 PM
http://www.scriptasylum.com/rc_speed.html
be sure to put in a value for the "ballooning" factor as it makes a HUGE difference in top speed
brushlessboy16
08.05.2008, 05:37 PM
or just strap the tires and forget about it :D
dpb318
08.05.2008, 06:25 PM
i did, i put a ring of duct tape on the insides and am running trinity three stage foams and still get a little ballooning, although thats bound to happen when a savage goes 50 mph lol
brushlessboy16
08.05.2008, 06:40 PM
maybe thats why your 9xls die, trying to gear for 50
dpb318
08.05.2008, 07:18 PM
im guessing thats why, i didnt do it on purpose lol...i didnt put anything in the calculator for ballooning so i thought i was only going like 35...though it did seem faster than 35 haha...i hope my problem is that im way overgeared...since thats easy to fix
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.05.2008, 08:28 PM
After reading this maybe I will install my roll bar .
dpb318
08.05.2008, 09:14 PM
it cant hurt...
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.05.2008, 09:20 PM
it cant hurt...
O it will. It's going to screw up my brakes I know it.
dpb318
08.05.2008, 09:39 PM
how?
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.05.2008, 10:28 PM
I have a fairly low torque servo running the brakes but it works well enough to make the heavy savage endo. I am using a very short servo horn though and the roll bar will be in the way of the linkage so it would need to be bent and that will act like a spring so the brakes will not work as well which will mean I will land on my back side more. It's a catch 22.
dpb318
08.06.2008, 12:04 AM
ahhh got ya, yeah my mechanical breaks suck at the moment, i need to redo my linkage, so a longer servo horn will prevent the need to bend the linkage?
ill try and get some pics of the completed rig up soon...you can then see my horrible brake setup lol
MTBikerTim
Yip Yip Yip...
MTBikerTim's Avatar
08.06.2008, 12:17 AM
Yeah a longer servo horn would fix it or at least will require less bending. Problem with a longer servo horn is it will need a higher torque servo to get the same amount of power to the brakes.
bl-is-future
bl-is-future's Avatar
08.06.2008, 09:23 AM
dp try 18/46 gearing. everythign runs extremely cool and it is cray fast. Not sure on actual top end but i can rarely get it to WOT
