07.11.2008, 05:35 PM
BrianG: Do you know what brand of DVD player it was? Do they still make them with the LiPo cells? That's definitely an accident waiting to happen with all of the charging/protection circuitry in the PS. Was there even a proprietary connector on the charging port?
Can't remember the brand, but it wasn't your typical brand. And no, the connector was just your typical center pin and sleeve type...
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
07.11.2008, 06:12 PM
That has to be illegal!
auto2
07.12.2008, 07:27 AM
the charger was set to 2s 4000. correct for the battery. is is th 606i and it never stopped charging cause the balance tap when hooked up must be the deciding factor on end voltage.
battery "looks" fine. i hooked it to a 12v test light bulb for gesh 2 hours? more? and it still has 8.7 volts in it. Oh and the thoought of putting it in a $1000 truggy to drive around was :-)
yea only a $70 pack i use in my started box that i dont use anymore cause i run BRUSHLESS!... i had 2 of them and taped them togeather to make a 4s pack as a practice pack and was charging them at work in a rush . ( dumb)
