ReV:-O
RC-Monster Carbon Fibre
08.08.2008, 03:09 PM
ok guys i've truly gone off maxamps now!
Originally Posted by SunnyHouTX View Post
i went through all 25 pages of all their suitable batteries and i found 5 *possible* batteries:
(with the 3s batts, i would order 2 of them)
1:
PQ-5000XP 3S1P
Capacity : 5000mAh
Cell Model: PF 8643150XP
Voltage : 11.1V
Charge Current(2C) : 10.0A
Continous Dis.(25C) : 125.0A
Dimension(mm) : 28.5 * 49.0 * 163.5
Weight : 389g
http://www.enerland.com/product/p1.p...oname=&page=15
2:
PQ-5000XP 6S1P
Capacity : 5000mAh
Voltage : 22.2V
Dimension(mm) : 54.0 * 46.5 * 166.5
Weight : 750g
http://www.enerland.com/product/p1.p...oname=&page=16
3:
PQ-6000XP 6S1P
Capacity : 6000mAh
Cell Model: PF 10343150XP
Voltage : 22.2V
Charge Current(2C) : 12A
Continous Dis.(20C) : 120A
Dimension(mm) : 66.5 * 48.0 * 168.0
Weight : 926g
4:
PQ-4500XQ 3S1P
Capacity : 4500mAh
Cell Model: PF 8143150XQ
Voltage : 11.1V
Charge Current(2C) : 9A
Continous Dis.(30C) : 135A
Dimension(mm) : 27.0 * 54.0 * 168.5
Weight : 416g
http://www.enerland.com/product/p1.p...roname=&page=6
5:
PQ-4500XQ 6S1P
Capacity : 4500mAh
Voltage : 22.2V
Dimension(mm) : 50.0 * 47.5 * 169.0
Weight : 714g
These all look ok, but my only problem is the pretty low mAh rating (and low C rating on a couple of them). all the batteries i was looking at before were all 8000mAh and above, and this kinda feels like a step down. how much runtime am i looking at, generally, with 5000mAh?
Many many thanks
Finnster
KillaHurtz
Finnster's Avatar
08.08.2008, 04:23 PM
out of curiosity, how much were you quoted for the big MA pack?
As already said, the "C" rating can be real BS at times depending on the company as there are no real stds. They are not necc lying, but they may be "optimistic."
The only way to really tell is to see discharge graphs and compare performance, as well as anecdotal reports. If a battery is getting hot during use, its pushed too hard.
If you want 60 mph out of a Muggy, then you are going to need a lot of power. I would plan on 2500-3000W peak or so. For 6S, this means about 120-150A peak. If a batt truely does 125A continous you will be fine. However, 3000W out a 1515 is going to start pushing the motor perhaps, esp on a hot wind like a 1Y. If you don't already have the motor, I may think about a 1521 even so you don't possibly overheat and/or use thegreater TQ to gear up and hit your spd goal. 60mph in a big MT is really really fast.
jayjay283
jayjay283's Avatar
08.08.2008, 04:26 PM
Originally Posted by bl-is-future View Post
Thunder power is listed and i was once told that thunder power and flight power are the same company.
Ive heard that also, I meant that Flightpower was absent from the list on that website for purchse of enerland options.
Finnster
KillaHurtz
Finnster's Avatar
08.08.2008, 04:41 PM
BTW, the Zippy-H packs are supposed to be very very good packs at an awesome price. A number of airplane/heli guys claim they are enerland quality, but just not matched like you would get on a Neu, PQ, FP or other pack. They are too new to really know the long term stability of the packs, but for 1/3 the $, its hard to go wrong.
Zippy packs @ Hobby city
Zippy 6S 5000 mah (20C)
4800 25C
Or failing that, go 8S and less amps :)
VintageMA
VintageMA's Avatar
08.08.2008, 04:57 PM
Originally Posted by ReV:-O View Post
yeah thanks man i fully appreciate all your help. i think u've more or less steered me away from maxamps now! lol.
when working out the continuous current, dont you do amps x C rating?
so VintageMA, how can you say 25C is more than u'll ever need? because that depends on the mAh. like you can have a 4000mAh 25C lipo, but that would only be 100A continuous (4 x 25 = 100), so this isnt good enough for any Neu motor. i still think the 5000mAh 25C flightpower pack will be cutting it real close because it will be only 125A...
or am i still missing something lol
There are many things you need to take into account when figuring out the current that you will draw. The kv of the motor, the size of the motor, the gearing, the weight of th vehicle, the size of the tires, etc. None of them are exactly the same and none of them will be exactly consistent from one setup to another.
When you look at the max. continuous amp rating of a motor, that in NO WAY specifies how much current the motor will actually draw. And it only specifies the amount of current the motor can handle at the max rated voltage.
Let's take the values for the motor that you are talking about: 1515/1y:
Specifications:
2200 RPM/Volt
volts: 7-25
Max Amps: 110*
*30 sec. at max. voltage. Otherwise, =Watts/your voltage.
Efficiency: 90%+
Rm (ohms) 0.006
IO: 2.5
1500 Watts Continuous
2700Watts - 30sec
Max rpm: 60,000
Stator Dia. 1.5"
Magnet/rotor length 1.5"
Shaft: 5mm
Shaft length: .75"
Weight: S-340g, F-360g
Dimensions 2.7"L x 1.56" dia.
The max amps is specified for 110A at the max voltage of 25volts. This is calculated using the power equation P=VxA. So P/V=A. For a 4S setup the max amps the motor can handle is 2700/14.8= 182.4Amps for 30 sec. On a 6S setup it is 2700/22.2 = 121.6Amps.
Looking at this rating doesn't really mean too much for battery selection though because it doesn't mean that your truck will draw 120 Amps for the period of the full run - even with a good 8000mAh pack it would last for 3 minutes runtime. Your Amps peak at startup and at full throttle, but most people will see an average over a 15 minutes period runtime of anywhere between 15 - 25Amps.
This is where the cont. and burst ratings for the packs come into play. At 25C a 5000mAh pack can put out 125 continuously (with decent air flow cooling) and in small bursts (ie: startup acceleration) can put out 50C = 250Amps. This is why I saw it is more than you will ever need.
And with the better quality packs you will be able to hold higher voltages ~3.4-3.5 volts/cell at these higher Amp draws; whereas, with the MaxAmps packs you will see that at such a high amp draw your voltage may drop down to 3.0-3.1 volts/cell.
Any of the Enerland packs people are talking about are really good quality cells.
I personally use the ThunderPower eXtreme V2 packs because all of my charging and balancing equipment is setup for the TP balancing jacks.
As an example of current draw, I am running the 1515/2.5D (1700kv) in my e-Revo with a 6S 5000mAh pack and my max power draw is around 1500watts which comes out to ~70 Amps max. The pack voltage always holds above 3.5 v/cell and I've yet to run down the packs fully but I estimate about 30 minutes runtime for this setup.
You also have to remember that a model of a certain weight generally take a certain amount of power to move around regardless of the number of cells you use. My XB8 takes about 1200 watts to move around so whether I use 4S 5S or 6S it still draws about 1200 watts max, it's just that at 4S it has to draw more current to reach that power than it does at 6S with the higher voltage.
I think a 6S - 5000mAh pack will be more than enough to push any 1/8 MT around happily.
IMHO - I think it's silly to stick 8000+ mAh packs into a 6S setup as all you are doing is increasing the weight of the vehicle and making it draw more current. With 5000mAh you will have plenty of runtime and a more efficient vehicle.
“Everyone has a right to be stupid; some people just abuse the privilege.”
ReV:-O
08.08.2008, 05:52 PM
thanks for all ur superb replys, i feel i am begining to learn... lol
the guy at maxamps quoted me $550 for the pack - which i am now not getting
heres a 62mph revo: http://www.youtube.com/watch?v=85v85Pn3DMk
ok, going by your advice i've made a new list of batteries
(i found all of these lipos at http://www.rclipos.com/RCL.html)
1:
Elite EL6S-5300 Li-Poly Battery In Stock $306.00
22.2V 5300mAh (6 cells) 30C/50C
Rating: 30C (159.0A) continuous, 50C (265.0A) burst
Dimension: 188mm x 46mm x 42mm
Weight: 800 grams
Termination: 10AWG wire leads
Request PQ / HP, AL or TP taps during checkout
2:
Poly RC PQ-6000XP-6S Li-Poly Battery In Stock $388.63
22.2V 6000mAh (6 cells) 25C/50C
Rating: 25C (150.0A) continuous, 50C (300.0A) burst Dimension: 165mm x 46mm x 64mm
Weight: 886 grams
Termination: Wire & PolyQuest/Hyperion tap
3:
http://www.impaktrc.com/product_info...oducts_id=2847
4:
PolyRC 6000 MAh 6S 22.2volt 25C pack
Cell Count: 6S - 22.2 volts.
Capacity: 6000mah
Pack Plug: None (You will need to add your own connector)
Tap Style: PolyQuest Style
High Performance Lipo pack
5:
PQ-5000XP 6S1P
Capacity : 5000mAh
Voltage : 22.2V
Weight : 750g
6:
Thunder Power RC eXtreme 9000mAh 22.2V 6 Cell Li Poly 6s 9000 Lithium Polymer Battery
http://www.rctoys.com/rc-toys-and-pa...Y-BATTERY.html
7:
Thunder Power TP9000-6S2P Li-Poly Battery In Stock $599.99
22.2V 9000mAh (charge as 6 cells) eXtreme Series
Rating: 20C (180A) continuous, 50C (450A) burst
Dimension: 195mm x 48mm x 73mm
Weight: 1332 grams
Termination: Wire & Thunder Power taps
i particually like numbers 6 and 7 (i think they are the same) but i would have to buy a specific charger and balancer for the battery, as they seem to use their own brand. are thunder power related to thunder tiger, because i heard they wernt so great...
VintageMA
VintageMA's Avatar
08.09.2008, 12:28 AM
I highly recommend you check out www.rclipos.com. Good prices and great service and shipping. Use the code poly4me at checkout as a promo code and you will get 10% off your entire order.
If you are going to go for TP cell, make sure you go for the eXtreme V2 cells as they are the newest and highest rated. A 6S 5000mAh pack is $300. With discount above you could get for $270.
TP5000-6SXV
22.2V 6-Cell
726grams
50x45x160mm
$299.99
Honestly I would go for 2 or 3 or 4 or 5. I would not go for 6 or 7 as those are the original eXtreme V1 cells which are not as highly rated.
As far as I know Thunder Power and Thunder Tiger are not related - but I could be wrong. Would want someone else to confirm that one.
lutach
lutach's Avatar
08.09.2008, 01:24 AM
On my BPP I went from 6S1P 5000mAh to 5S2P 7700 (2 5S 3850mAh) and 5S2P 9200mAh (2 5S 4600mAh) packs and I enjoy my nice long run times.
azjc
08.09.2008, 01:48 AM
1:
Weight: 800 grams
2:
Weight: 886 grams
3:
4:
Capacity: 6000mah
5:
PQ-5000XP 6S1P
Capacity : 5000mAh
Voltage : 22.2V
Weight : 750g
6:
7:
Weight: 1332 grams
options 6 an 7 both weigh 1.3kgs...way too heavy try to keep the weight around 750 grams, and for the price of the 9000mah 6s pack you could get 2 5000mah 6s Flghtpower packs and get more run time between the 2 packs...the heavier the truck is the more it will drain the pack
1maxdude
08.09.2008, 05:48 AM
Sounds like Maxamps is the new Venom of lipos. Higher priced, lower quality, popular with the uninformed. Yeah, I was the one questioning the "hate" of maxamps. Your guys' applications are totally different and uncomparable to mine. Personally, my pack suits my needs so I'm not going to come in here and try to defend them and have this guy spend 550!!!???!! on their battery. Obviously, if you guys can get away with running 1p, then them trying to sell a 2p battery says something about them. Especially when its such a high capacity and they still want to go 2p.
bl-is-future
bl-is-future's Avatar
08.09.2008, 10:04 AM
ic what you are saying now, yeah makes sense
glassdoctor
TEAM FUSION
glassdoctor's Avatar
08.09.2008, 12:29 PM
I love my 12000mah pack LOL!!!!
You gotta see the face of the nitro guys when they hear how long my CRT can run on a charge... good stuff.
But I don't recommend a pack this big. I did it only for runtime.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
ReV:-O
08.09.2008, 07:22 PM
if i should get a 1521, which one should i get?
1521/1D 2900kv
1521/1.5D 1900kv
1521/1Y 1577kv
1521/2D 1425kv
1521/2.5D 1200kv
1521/1.5Y 1050kv
1521/2.5Y 630kv
1521/3Y 525kv
as you can see, all except the 1D have lower kv ratings, so they will be slower than the 1515/1y. i dont think it will be possible to achieve 60mph with a 1521
bdebde
That's All Folks!
bdebde's Avatar
08.09.2008, 07:49 PM
1521/1D 2900kv
1521/1.5D 1900kv
1521/1Y 1577kv
1521/2D 1425kv
1521/2.5D 1200kv
1521/1.5Y 1050kv
1521/2.5Y 630kv
1521/3Y 525kv
The 1521 1Y is popular for 6s, and I don't see why you think you won't achieve 60 mph on a 1521...
Differential Ratio: 4.09
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 20
Total Voltage: 22.2
Motor KV: 1577
Tire Diameter (inches): 5.8
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.008
Spur/Pinion Ratio: 2.3 : 1
Total Ratio: 9.407 : 1
Tire Circumference (inches): 18.22 inches (462.82 mm)
Total Motor Speed: 35009.4 RPM
Vehicle Speed: 64.22 mph (103.15 km/h)
Estimated Adjusted Speed: 59 mph (94 km/h) - 9% loss
Effective KV Value: 1577
KT constant: 0.86 oz-in/A
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
ReV:-O
08.09.2008, 08:14 PM
woah if i can get 59mph and the motor is only spinning at 35000RPM, imagine how fast it could go with the 1515/1y spinning at 50000RPM!
