Go Back   RC-Monster Forums > Support Forums > Novak
crazyjr
crazyjr's Avatar
11.12.2008, 02:49 AM
Originally Posted by tt-01 mamba View Post
Shhh,
You can't say the M word in novak's territory.
I'm just telling my story, I never said anything bad about Novak. But for future eference, I'll use brand-M and brand-Q. As I said, I wouldn't have any qualms about running a Novak in racing. I think the highest turn motor would be perfect for 4s Lipo in a Nitro mosh pit of a race
Sorry if i offended Novak in any way
NovakTwo
Senior Strategist
11.14.2008, 01:42 PM
The Novak company is not full of sensitive, delicate flowers...
Novak Electronics, Inc.
Maxxrickard
Maxxrickard's Avatar
05.11.2009, 06:42 AM
what gearing do you guys rekommend in my grevo?
i have a HVmaxx 4.5 and use maxamps 2s lipo.
today i use 15/72 and dont like the speed. i need the car too get qicker.
TexasSP
Something, anything, nothing
TexasSP's Avatar
05.11.2009, 02:01 PM
Novak doesn't leave a lot of room for gearing options. If that is their recommended gearing then you are pretty much stuck.
Of course I am assuming you are using 2 x 2s packs for 4s total?
My recommendation would be to look at the MMM combo or the Tekin RX8.
www.cubicle101.com
Maxxrickard
05.11.2009, 02:08 PM
no it is not what their recommend. i have today 15/72. but i need moore speed.
http://www.teamnovak.com/products/br...ems/index.html
i think emaxx original is 68t. and they recommend 12t. so i think i will try 12/70. anybody that have used that gearing??
05.11.2009, 02:26 PM
12/70 is slower than 15/72 - The reason they choose the gearing is to avoid overheating - just gradually up the pinion and check for temp issues.
Maxxrickard
05.11.2009, 04:32 PM
is that true?bigger pinion is the trick!
thats bad i hav allready order 12/70...
05.11.2009, 04:34 PM
Well you said you wanted to go faster...
15/72 = 4.8 revs of motor for 1 rev of input shaft
12/70 = 5.8 revs of motor for 1 rev of input shaft
i,e, 4.8/5.8 i,e, 18% SLOWER!!!
Just think you can now run 15/70 = 4.666 revs of motor for 1 rev of input shaft
Should be about 3% faster if you can notice...
Maxxrickard
05.11.2009, 04:44 PM
in Novaks test is 12/68 faster than 14/68 is.
can i get moor speed in an other gearing than 15/70?
the temp is not a problem because i the esc have samr sort of temp protection
05.11.2009, 05:02 PM
They can still cook even with thermal protection - faster with lower gearing would imply over geared already i.e. motor can't spin faster.
A bit like driving in 5th gear up a hill if you drop down to 4th you can actually go quicker...
Basically you have too more options to try... 12/70 lower gearing to see if that was holding the car back or gear up and see if motor will take it with 15/70
Maxxrickard
i did send an email and change my spurgear to 66t
i will try 15/66
15/66=4.4
Maxxrickard
05.11.2009, 05:09 PM
i need my car to get quick not high topp speed!!!
05.11.2009, 05:24 PM
Gear DOWN for faster acceleration - gear UP for faster top speed...
when you said more speed I took as top end vs acceleration... 12/66 should still be ok...
Maxxrickard
05.11.2009, 05:34 PM
okey but if i just need acceleration?
12/66 gets the best acceleration and gets okey topp speed?
i like when the car makes wheelis..
05.11.2009, 05:41 PM
Try the 12/66 or buy a mmm and do backflips...
This is a Mamba Max on 4s with a 9XL
http://s168.photobucket.com/albums/u...urrent=018.flv
http://s168.photobucket.com/albums/u...urrent=017.flv
