cwallis
10.06.2008, 01:22 PM
My first MMM stopped after 20 minutes on 4s, I then saw the great price that Monster Mike had on the MMM's so I thought I would try my luck and it has paid off. I am finally able to enjoy my first electric truck. I am still running on 4s in an erevo with a Neu 1515 1.5D.
FastXR
10.07.2008, 09:22 AM
I just installed a MMM V2 in my brushless converted CEN Matrix truggy (JHautz you will remember this one!), Im running 5s lipo and a Fiegao 9XL for now until I can afford to upgrade to a Tekno Neu. So far three packs thru it and no problems, fan on the esc is hardly needing to turn on and everything seems to run well, the power is absolutely insane, it does wheelies at will. I'm taking it out to the track tonight to set up all of the esc settings for racing, right now its basically set to defaults.
UPDATE:
Took it to the track tonight, adjusted the punch control to about 50% and set the motor timing to Lowest setting since I knew I wouldnt need max power, took it out for about 5 laps and it was running great but still too much bottom end so I brought it in and adjusted the punch control up to the maximum and plugged battery back in turned the esc on and nothing, no lights, no beeps, nothing at all. Unplugged battery, redid the programming seemed to program fine, hooked back up still nothing. So much for that looks like another dead V2.
Fast5sRevo88
10.13.2008, 03:00 PM
I recieved my MMMv2 Saturday. I have to solder up some connectors before i test it, hopefully i will have a race soon to put it to the test. I plan to test it in my truggy with 9xl and 4s geared 46/11 with no mods on the ESC. What is the LVC default setting?
DickyT
10.13.2008, 04:22 PM
The LVC default should be auto lipo, but not a bad idea to plug in the castle link and take a peak before you run it. Maybe a few other things like lowest motor timing, low start power, dial in some punch control etc.
Fast5sRevo88
10.13.2008, 04:38 PM
Ok
