9l in crt .5?
bustitup
9l in crt .5? - 10.25.2008, 01:08 PM
anybody run one before.....I want to run just 3s or 2s in this truck...using a mm no bec?
stock spur and I want maybe 40-50 mph
10.25.2008, 01:25 PM
There are a few who have run that and like it. Stays relatively cool considering it's a Feigao. But, if you run 3s you should still use a BEC IMO...
bustitup
10.25.2008, 01:29 PM
I will use a bec than .......what pinion would you suggest and its mod1 correct?
10.25.2008, 01:31 PM
Pinion depends on speed you want really. And yes, it's mod1...
bustitup
10.25.2008, 01:38 PM
well I tried to use the calculater but it didnt have a choice for a crt .5 spur
and I dont know how many teeth are on a stock crt .5....I know I know go count the teeth.....to lazy right now
david lamontagn
10.25.2008, 01:43 PM
crt.5 spur, is the same as 1/8 buggy standard spur, 46t.
And if you want my 1509, 2.5d/s (2700Kv), i can sell it................
bustitup
10.25.2008, 01:49 PM
oh yes I offered you a trade....but I just sent a pm for price
the 9l is about the same kv and a heck of a lot cheaper but I know the neu is much better quality
i ran the calc with 46 spur and I cant hardly get it below 65mph....lol....you would need like a 10t
10.25.2008, 01:54 PM
65mph? What settings did you enter?
Differential Ratio: 3.25
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 46
Pinion Tooth Count: 14
Total Voltage: 11.1
Motor KV: 2731
Tire Diameter (inches): 4
Tire Ballooning (inches): 0
Spur/Pinion Ratio: 3.29 : 1
Total Ratio: 10.67857 : 1
Tire Circumference (inches): 12.57 inches (319.19 mm)
Total Motor Speed: 30314.1 RPM
Vehicle Speed: 33.78 mph (54.26 km/h)
Estimated Adjusted Speed: 32 mph (52 km/h) - 4% loss
bustitup
10.25.2008, 01:57 PM
lol....I see what I was doing wrong....i was entering 1/1 for diff's
btw there was no stock spur at 46t...you sure its not 48t?
Other Ratio: 1
Total Voltage: 11.1
Motor KV: 2731
10.25.2008, 01:58 PM
The stock spur on mine is definitely 46t...
david lamontagn
10.25.2008, 02:14 PM
The stock tires diameter on the crt.5 is not 4.0, but 3.5
bustitup
10.25.2008, 02:24 PM
btw there was no stock spur in the pull down at 46t...you sure its not 48t?
hint hint
david lamontagn
10.25.2008, 02:59 PM
My crt.5 will have my Neu 1512, 1.5d/s on 4s, with proline bowtie 30 serie.
SHould be nice setup for bashing
10.25.2008, 04:39 PM
A 1512 on 4s in a crt.5...look out!
david lamontagn
10.25.2008, 04:55 PM
i'am crazy, i know it, but i like to have more than not enough
