01.09.2009, 06:42 PM
Yes and yes - you need to make a series adapter - not sure if that charge has a built in balancer but you also need a 4s to 2x2s balance adapter.
Briang has the diags for it if you search
johndeerekid
01.10.2009, 10:40 AM
okay i found it, thanks!
i have a few questions through.
i want to get 2 of these- http://www.spcracing.com/index.php?productID=59 , are they good bateries?
also i was looking through that how to and it said i nned a LBA10 balancer and i looked at it and the LBA10 has charger leads too, so is it a charger and a balancer? if so does that mean that thats all i need to use or does it plug into my charger? if so cant i just use my charger and a Blinky( http://www3.towerhobbies.com/cgi-bin...&I=LXMRZ9&P=FR ) to balance and charge?
and also when i run the lipo's in my trucks do i need a LVC since the MM dont have one?? and what do i do with the balancing leads from the battery while im running the truck?
sry for so many questions. -Wes
E-fanatic
Brushless only!
E-fanatic's Avatar
01.10.2009, 11:08 AM
I belive the mm can be set with a castle link to custom voltage cutoff and set for a 4s lipo???
I would look at a battery that will provied a little more in the amp department. They have a 5200 24c that would be great! Or a 8000 12c (both are pretty inexpensive)
johndeerekid
01.10.2009, 05:01 PM
i was looking at the 2s 8000mah 12c but isint 12c too small? -Wes
E-fanatic
Brushless only!
E-fanatic's Avatar
01.10.2009, 06:23 PM
No(they are rated at 100amps contiues) I am useing true rc 8000mah 10c(80 ams and they run better than the enerland 6000 25c rated at 150amps) for my e-revo with the mmm and castle/neu 2200. There are many here that are useing the spc 8000s. I am going to be orderins some soon
johndeerekid
01.10.2009, 08:19 PM
sweet! well im deff going with the 8000's then.
buttt i still need help with the balancer stuff
-Wes
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
01.10.2009, 08:27 PM
Go with the Hyperion lba10 balancer! It's only a balancer, a charge through balancer, so you hook your charger up to it and then the balancer to the lipo.
E-fanatic
Brushless only!
E-fanatic's Avatar
01.10.2009, 09:36 PM
fma sells a cellpro 10s charger that can charge 2 of the 8000s at once and balance them(up to 10s at 10 amps ). They also make the multipro4 that will balance charge 4s li based cells and do nicad, and nimh and so on. They are great ballincing chargers.
A balanceing charger does a better job than a stand alone
E-fanatic
Brushless only!
E-fanatic's Avatar
01.10.2009, 09:37 PM
http://www.fmadirect.com/
