RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
12.09.2005, 11:38 AM
The 3695 could have a 42k rpm limit, or a 100k rpm limit, depending on the frequency of the controller(If you have a programming cable, you can find this out for yourself). I would absolutely agree with Serum, too. Keep the rpms around 35k to 40k and you will experience long term success in power, speed, runtime and system reliability. Gear the system to meet your speed needs withi these rpms and you will be happy in the end!
Promod
12.09.2005, 12:13 PM
Mike is 100% right!! You do not need to push these motors that hard to get speed and power. Use a low KV motor and gear for the speed. You will be rewarded with a cool running system and long run times.
Reving the motors that hard is old thinking and should be forgotten. In my stupid days I did the same thing 8s 18 cells,5XL 24 cells,7XL 32 cells. Than I learned about low KV motors and never looked back and went much faster.
Thank you,
Promod
mack
mack's Avatar
12.09.2005, 12:26 PM
Yep I also thougt that how higher the rpm how faster the car.
But SERUM convinced to go for the lower rpm/v enegine :D
VWT4
12.09.2005, 12:37 PM
Thanks for all the explanations.
I will try the XL12 with 21 cells (35.000rpm) and 24 cells (40.000rpm).
Which chassis do you think will fit 4 packs better, the new extended E-maxx Chassis by Fast Lane Machine or Gorillamaxx G2 X-Brace Chassis ?
mack
mack's Avatar
12.09.2005, 01:24 PM
[QUOTE]Originally posted by VWT4
[B]Thanks for all the explanations.
And yes we have anohter believer:D hallelujah:D
Promod
12.09.2005, 01:25 PM
The 12 XL is a great choice and will rock on 24 cells. Have fun!!:D
Thank you,
Promod
coolhandcountry
coolhandcountry's Avatar
12.09.2005, 01:27 PM
The gmaxx will have the cells lower to the ground. It will make your handling better like this. Are you going to stack 6 cells or build a pack with the cells in it?
Peace!
Country
Help support the
Rc-Monster
Buy here
VWT4
12.09.2005, 01:33 PM
My idea is working with 6 and 7 cells packs .
In the future I will get lipos.
