12.01.2008, 05:46 PM
Originally Posted by speedracer1129
Brian,
I thought you never got a chance to run it?? Did you get any info on it like speed, amp draw, etc. ??
I could get enough room to really let it rip. I got to maybe 60 when I could get the tires to get a hold. Anything more than VERY gentle throttle broke them all loose. As it is, I totally ripped apart a tire, and damaged 3 others (repairable). No idea on amp draw, but the HV110 was barely warm until it blew that one cap (45*F outside too so that helps). I don't imaging the amp draw was high since I could hardly touch the throttle.
12.02.2008, 12:23 AM
Sweet jesus this will be a fun video to watch!
Round 1 -
12.02.2008, 01:12 AM
Alright guys. Just got back from running the truck. Unfortunately, I had problems.... It seems that the center diff front bearing carrier broke down which caused the spur to shift and get completely chewed up!! On a good note, that was it so I will be visiting the local shop to pick up the parts to run it again Wednesday night. The truck looks very promising as I when I pulled it out to take it to the end of the street to line it up it clocked 71mph in 100 foot stretch!! I have video but I think I am going to wait to add it with Wednesdays' vid and edit it all. I will keep you guys posted!!
12.02.2008, 05:52 PM
wow, the suspense
12.02.2008, 11:31 PM
Alright. I got the car back together again. The bearing carrier failed and caused the bearing to fail as well. Everything has been replaced and I installed the upgraded aluminum carrier so I think I should be in good shape for tomorrow night.
12.03.2008, 02:31 AM
Speedracer,
Where do you run? I am in Ft. Lauderdale and would like to bring my speed projects out for testing..
12.03.2008, 04:51 AM
WOW 71 mph in a hundred feet! thats impressive considering my 30oz 6s dragster hits 104mph in 132". must be getting crazy traction. cant wait to see a vid.
12.03.2008, 09:22 AM
Originally Posted by killajb
Speedracer,
killajb,
We are running in different areas. Either at FIU on 8street in Miami on Wednesdays or 12th ave in Carol City on Wednesday nights and Sundays after 3pm. We will be at 12 ave tonight as the street is much longer and wider than FIU. In all honesty, I do not think I will run at FIU with this car as the calculated speed based on previous testing for this car won't allow me to run it there.....
You should definately go out as you will see alot of different vehicles!! I will PM my number so you can call me if you have any other questions.
Luis
I like chocolate milk
12.04.2008, 11:18 AM
Ewww. Sorry to hear about your bad luck. It's getting so used brushless is about as much of a gamble as used nitro nowadays. =/
12.04.2008, 01:35 PM
I agree.. A few weeks ago I purchased a used Lehner with supposedly "10 hrs" of runtime on it. Well, when the motor arrived one of the bullet connectors fell off after I removed the heatshrink! I was changing the bullets anyway to match my ESC, but that was a sure sign of foul play. In addition, the leads were all discolored and when I finally attempted to run it, the thing smoked~
I purshased my 1515 2.5D new and it's flawless. I purchased a 1515 2D new from TeknoRC and first ran it with 6S and an 18-tooth pinion on my Hyper 8. I only ran down the street, turned around and hauled back but the motor was getting pretty warm so I shut it off. I've since switched to 4S and a 14-tooth pinion, perfect temps and ideal for track use anyway.
I don't think I'll ever buy a used brushless motor again for fear that someone else will just ignore caution and beat the crap out of it.
12.04.2008, 02:59 PM
I agree, no more used stuff!! I am pretty picky about my stuff and I would feel bad if I was on the other end! I have spoken to a few companys already about the situation and they all seem to be on the same page that something happened to the motor before I got it. It seems that the a magnet came loose and rubbed against the can.
Oh well, I already spoke to Medusa and I am going to throw in a 80mm 1600kv when they come in.
12.04.2008, 08:05 PM
So you dont think that running the motor at its rpm limit and haveing the Center dif gears get chewed up when the dif bearing failed could have put any stress on the motor bearings? Seems pretty coincidental to me that the motor failed the next time you ran it. I wouldn't blame the guy you bought it from or the motor itself. Anything will break if you push it to its rpm limit and then add additional stress of chewing up gears. Thats the price you pay for pushing things to their bleeding edge IMO. You would have probably ruined a brand new motor doing that too.
to make it...
or break it...
Silent...But Deadly
12.04.2008, 09:00 PM
j,
I understand what you mean but here is the thing. I have confirmed with both Medusa and Neu on my situation yesterday. Both of them stated that the setup was not the problem. I am not pushing the motor to it's "limit". The motor is rated at 60k continuous use max, not it's absolute max. On paper, the setup pushes slightly over 60k, but in the truck it will only about 45-50 so I am in no danger as far as that is concerned. The fact when I tested the motor with the wheels off the ground I was getting high heat already. Funny thing is that I got 2 different answers on that. Medusa said it was possible that the motor would get to those temps in that scenario. Neu told me that that was happening because a magnet was already rubbing in the can due to something from before. They both did say that it seems that the motor failed due to a magnet or magnets becoming loose and rubbing internally which caused the failure once it tried to pull the weight of the truck. Lastly, the center diff gears don't exist in this truck....In other words, this truck has a custom solid spool that uses a plastic spur gear on it...that is it! If you are picturing a bunch of chewed up metal, that is not what happened. If it was, we wouldn't be having this conversation!!
12.04.2008, 10:08 PM
j,
I cant help but wonder if the 30k rpm separated the magnet or the 60k rpm.... Hmmm
to make it...
or break it...
Silent...But Deadly
12.04.2008, 02:39 PM
VIDEO!?? where is the video ???
P.S.
Looks like a great project..
