rchippie
rchippie's Avatar
03.05.2009, 11:28 AM
check out tcscrawlers plates they are pretty cheap...
I checked but could not find this plate .
http://www3.towerhobbies.com/cgi-bin...?&I=LXTCY2&P=7
REAL MEN RUN BRUSHLESS
skellyo
skellyo's Avatar
03.05.2009, 11:34 AM
http://www.tcscrawlers.com/Axial-AX1...6-p-16625.html
rchippie
rchippie's Avatar
03.05.2009, 06:34 PM
Chris did you use all seven braces ?. I cant figure out were they all go .
03.05.2009, 07:06 PM
nah - i dropped at least 2...
rchippie
rchippie's Avatar
03.05.2009, 07:26 PM
Im having issues with mounting my links & need help. . Is this the size of your upper link ?.
http://www3.towerhobbies.com/cgi-bin...?&I=LXUUK5&P=7
Ride height
rchippie
rchippie's Avatar
Ride height - 03.12.2009, 10:07 PM
What ride hight at the bottom skid is good ?.
03.12.2009, 10:14 PM
I believe I used one set of internal limiters.
I set it up to keep the links flat. Not sure how much clearance that is.
Note I'm new to this and not an expert by any means.
rchippie
rchippie's Avatar
03.12.2009, 10:19 PM
I used i thick & thin internal limiter per shock or just about 1/4 inch . With my links level i have 2 1/2 inch of clearence on the skid . One of my shock bodys is bad . so Horizon is sending me a new one . so i wont be able to use my truck for just a little longer . I also need two more 40mm screws to finish the stage 2 mod .
Update
rchippie
rchippie's Avatar
Update - 03.18.2009, 04:36 PM
My replacement shock bodys came in today . I installed them & now my crawler is running . I noticed the wheel rubs the shock springs at full lock . Does anyone else have this issue ?.
03.18.2009, 06:42 PM
yes... does the same...
rchippie
rchippie's Avatar
03.18.2009, 07:20 PM
Okay .
