rrgirgis
rrgirgis's Avatar
12.14.2008, 07:57 PM
Originally Posted by E-fanatic View Post
Well put a hole in the windsheild today to see if it would help. Geared 20/65 it never broke 125 in the yard after 15+mins. My pinion slipped and killed the spur so I put a 58t on it and after 10mins I checked it and it was 131. I am surprised that the 1 1/2in hole helped out so much. It was 45* out today. Apparently the e-revo body doesnt let much air in there!
Awesome, that's great to hear that the holes in the windshield will yield a noticeable reduction in temps, that is the next thing i will do when i run again and post my results as well... as pdelcast said airflow is key!
e-fanatic looks like were were getting around the same temps and now they are working to our favor with more runs and some testing
12.14.2008, 07:37 PM
Lol.
Airflow is an r/c enthusiasts best friend- whether its airscoops or holes in the body, or a fan on the motor/esc (dont tell Brian), airflow is the key to reducing temps, so put your whip away and you might learn something
hemiblas
hemiblas's Avatar
12.14.2008, 09:11 PM
Lol.
I'm still running the 7XL with no problems. I know you like to refer to this motor as the spinning toaster of death, but when summer came around I added the novak heatsink and some fans. Never let the can get over 170 degrees and it runs as strong as the first day I put it in. Now that winters here a little airflow over the heatsink and its good to go. I have more than gotton my monies worth out of this motor and still the only way I can describe it is crazy fast. Oh BTW, MMM V3 is still running strong. OH YA!!!!!!!!!!!!!!
Savage03
12.15.2008, 05:02 AM
Are the esc's water tight? ONly suky part of putting holes in teh body lets more bad stuff in to lol.
rrgirgis
rrgirgis's Avatar
12.15.2008, 11:12 AM
The ESC are "Water Resistant" as they have a coating around the circuit board but im sure its highly recommended not to run it where any kind of water can get to it
E-fanatic
Brushless only!
E-fanatic's Avatar
12.14.2008, 08:06 PM
I'm just happy my temps are down! I just wanted to let you all know the temps were from my set up and now have it fixed! I have no issue telling anyone if its my own fault! I do think I might go to a 62 or 65 spur when on the dunes just to be careful!
phatmonk
RC carbon junkie
phatmonk's Avatar
12.15.2008, 04:13 PM
I received my combo today and the Neu/Castle motor has play in rotor shaft/output shaft, about 1mm.I dont have this play in any of my Genuine Neu motors.If that pinion on the motor moves forward into my E-Slayers slipper clutch thats bad.Like I said my 1515/1y has no movement in the rotor shaft.
E-fanatic
Brushless only!
E-fanatic's Avatar
12.15.2008, 07:24 PM
all my brushless motors from castle, hacker, lehner, and feigao have had a little play. A few 5mm shims would sure it up if you really need.
MetalMan
MetalMan's Avatar
12.15.2008, 09:36 PM
That's right, most motors due have some play between the rotor and bearings. A lot of times brushed motors have play as well, and for them a tighter tolerance is more critical (commutator + brushes).
SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
12.16.2008, 04:54 PM
You can always add shims to prevent this.
Area 52 Ranch Raceway
T.R.C.R.
phatmonk
RC carbon junkie
phatmonk's Avatar
12.17.2008, 05:39 PM
So take off the frontplate and put the shims where?Between the front bearing?
E-fanatic
Brushless only!
E-fanatic's Avatar
12.17.2008, 07:05 PM
I would put them between the magnet and the spacer. So the brass spacer is still against the bearing(in sure they put that size of a spacer in there for a reason) It probably doesnt matter but thats me just thinking out loud.
Carraig042
12.17.2008, 10:58 PM
Just though I would add my gearing and temps to the review for others to see.
Outside temperature= 55*
Motor= never over 110*
Neu 4s batteries= never over 75*
MMM= not sure, but the fan never turned on.
Gearing in E-Revo= 19p 56spur
That was in shorter runs lasting no more then 15 min at a time on the road since it was raining off and on today. Power seemed great! A lot of torque on demand. I can't wait to get a run in with dry weather... someday.
Tomorrow, weather permitting, I am going to try 19p 54spur and see if there is much of a difference in speed.
-Brett
Burnsi
12.18.2008, 12:01 PM
are these motors better on 6s a123 than the bidproducts motors?
will these increase my runtime?
http://www.bidproduct.com/part/Produ...MOTOR_184.html
will this motor have more power than the bidproduct?
i see i can get 2200k/v only, is this not to much for 6s a123?
12.19.2008, 09:15 PM
Bidproduct motors = better built feigaos. They are cheaper, and use a one-piece magnet vs the segmented magnets inside feigaos, but they give pretty much the same performance and temps/efficiency.
For 6s A123 like I run (= ~5s lipo), I'd say the 1900kv option would be best or there abouts, but the 2200kv MMM motor will be more powerful and efficient for sure, just gear down a touch to compensate for the higher kv/motor rpms.
