sleebus.jones
I like chocolate milk
sleebus.jones's Avatar
12.14.2005, 09:19 AM
Originally posted by boss 302
what are the advantages of the external UBEC device over the controllers BEC device?
Generally it can handle more power than the BEC on the controller. Also, if you do something to smoke the UBEC, it's a $35 fix. If you smoke the one on your speed controller, it's a $200 fix. :eek:
Cheap insurance.
Michael
boss 302
12.14.2005, 09:28 AM
thanks i think i will pay th extra $35 dollars when i by the controller and motor
andy
boss 302
12.14.2005, 08:42 PM
is there anything else i should know about these motors and controllers
MetalMan
MetalMan's Avatar
12.14.2005, 08:59 PM
Only that you should have fun :). Just keep the controller away from water, and put a piece of tape over the rear bearing on the motor to keep debris out of it.
boss 302
12.16.2005, 11:11 PM
Just to make sure i can use the UBEC device with the warrior 9920 and a bk 8xl or 9xl cant i? and what temps would the controller and motors run(so i know what to expect)
Andy
squeeforever
squeeforever's Avatar
12.16.2005, 11:15 PM
yes you can use a ubec and the controller shouldnt go over about 150 at most and motor about 160 but with that motor and setup with a ubec it should run way less.
boss 302
12.17.2005, 10:27 AM
What would the temps with ubec be like and is there a way to hook up a fan up to the controller?
boss 302
12.17.2005, 01:19 PM
What connectors would i need to get to hook the controller to the motor. I currently use deans for my batteries
Andy
squeeforever
12.17.2005, 01:26 PM
from the motor to the controller you would use these. not sure on the ubec temps but 10 degrees cooler would be my guess.
MetalMan
MetalMan's Avatar
12.17.2005, 02:48 PM
I don't think you can compare the temp of the controller with BEC to the temp without BEC. The BEC chip doesn't touch the heatsink, and it is on the underside of the controller. But, it certainly won't get hot if a UBEC is used.
Gustav
Gustav's Avatar
12.17.2005, 03:19 PM
If you're buying a wanderer XL you'll need 3 of these not the 3.5mm plugs.
boss 302
12.18.2005, 05:11 PM
thanks i should be getting the setup before 2 long (after christmas)
andy
