brushlessboy16
brushlessboy16's Avatar
03.29.2009, 06:37 PM
does it run 8mm stub shafts?
03.29.2009, 07:02 PM
Yep, seems like the cen 23mm hubs are the cheapest way to go...
brushlessboy16
04.01.2009, 08:24 PM
I may have a few Off of my matrix. Pm me
04.09.2009, 02:18 PM
Made a little progress. Made the top support, both side fillers and the center and rear skids.
Pics show it mocked up with the moab tires. Need another pair of 23mm hexes and I can put the front wheels on. Still need to rebuild the front diff and swap the lst1 arms and hubs for lst2 parts. Also need to pick up another pair of aftershock shocks (running 4 of those in the rear to lose a little weight).
Thinking I may put the motor in front of the tranny, and the battery behind it. Still need to make the new center chassis plate, and the single servo will interfere with battery mounting in the front.
I also need to dye the green plastic side fillers/braces black, they look kinda funky in green (material was free, so I could not complain!). And i need to fab up a motor mount... Still plenty to do with this project...
04.09.2009, 04:22 PM
looking good
its me
There is no help for me... I'm addicted to R/C
its me's Avatar
04.11.2009, 03:40 PM
I like it man looks really good :)
Soo do you have any thoughts about what body your going to use?
rccna.com
04.11.2009, 04:20 PM
Thnaks! I was either going to use one of the 18 wheeler style bodies from proline, or buy the tsr body (that body is kinda ugly...).
its me
its me's Avatar
04.11.2009, 05:40 PM
Ah! my only plan for the body was to find a large enough cab that might fit most of the wheel width under and then match that by buildin fenders like those on a real semi. Im in the same boat as you cant really find a body that tickles my pickle :)
On a side note do you have a picture of you plastic welder? been wondering what that looks like?
rccna.com
04.09.2009, 04:33 PM
I have tool envy...
04.09.2009, 05:16 PM
looking good
Thanks Harold... The end is near, just need to make some more parts!
I have tool envy...
The bandsaw was 100 bucks, and the smaller drill press was about 125. The larger press in the back was a harbor freight special. Lots of power, but the bearings wore out fast... I guess I could change them, but it was a 60 dollar press...
I would recommend a bandsaw to anyone, I usually use it to cut plastic, but it will cut 1/8 al like butter. Better models are available, but it was a gift, and I have easily got my money out of it!!!
Spend some money on some tools Chris, you will not regret it!
04.09.2009, 08:19 PM
Very nice. Those beadlocks look familiar. :)
04.09.2009, 08:31 PM
One of those projects that takes A LOT longer than expected....I can relate
Yeah, the small stuff just takes longer than expected... Could be worse, at least the concept is sound.
Actually the ones that are not on the truck would look alot more familiar...
04.09.2009, 05:59 PM
Looks good..look forward to seeing it done
04.09.2009, 07:45 PM
You and me both...
04.09.2009, 08:08 PM
You and me both...
