Any ep diff between x1 CRT vs x2 CRT?
superek4
superek4's Avatar
Any ep diff between x1 CRT vs x2 CRT? - 03.14.2009, 05:45 AM
Hi, I m currently racing with my x1 CRT. was thinking to change to x2 CRT. I m using Rc monster's motor mount n servo tray. izzit worth d change n can I still use d same conversion kit?? I m using big bore shocks btw.pls advise thx
Cartwheels
02.16.2009, 04:42 PM
Buy a few of those Kyosho spurs, they will break on you sooner or later. You'll get good at tearing down your truck to replace the spurs. I like the hardened steel option much more combinened with the hot bodies lsp diff and pinions. The Hot Bodies parts are nice. I really like the spiral cut gears. If you have the money this is the way!
Steve182
Steve182's Avatar
02.28.2009, 02:25 AM
Thanks for the info man I appreciate it. Seems like 14-16t pinion is the way to go and is what most people are having good luck with. Im waiting for the Zippy Flightmax's to come back in stock on HobbyCity now....
| Hyper 8 Pro- MMM, Castle 2200kv / Zippy 4s 5000mah
| Jammin CRT- MMM, Feigao 10XL, 5s Zippy 5000mah
| Savage Flux- Castle 2200kv Combo, 6s Zippy 4000mah
  Send a message via AIM to Steve182
