Freakycrawler
08.14.2009, 05:19 PM
Originally Posted by teknorc View Post
These are not intended for truggy use. They are just a tad too small. Go with a 1515 or 1512 based motor instead (1515/2.5D or 1512/3D).
Thanks you very mch, nice and quick reply'ed also
I will look into the ones you advise.
Thanks you guys
Topas
09.10.2009, 04:53 PM
Do I need a fan on the motor (Lektron 2200) in a Losi 8ight 1.0 Buggy ? After 10 minutes it is about 74 degrees C hot (gearing 45/15)
My hobby coin collecting: (in german)
Euromünzen
danhfvcsd
09.10.2009, 06:30 PM
I wouldn't think so... you could gear down the pinion a tad if you have the room for it, but a fan wouldn't hurt it if you wanted to run one i think... My tekno neu 1512 gets around those temps in my RC8, and it's fine =)
Topas
09.11.2009, 01:43 AM
But it isn´t a neu 1512 ...;) The manual tells : Don´t let the temperature go above 78 C ... So if I drive a 20 minutes main I will run into problems ...
Euromünzen
danhfvcsd
09.11.2009, 02:32 AM
thats a good point - my temps are almost at that after a 20 minute main, not 10 minutes....
Try gearing down on the pinion, and lose some weight if its possible... it should run a bit cooler then... or simply add the fan and see how it goes =)
