View Poll Results: Do you want new switches
Yes 76 84.44%
No 14 15.56%
Voters: 90. You may not vote on this poll
04.22.2009, 06:04 PM
A circuit breaker has several disadvantages:
- They operate too slow. You could have a fatal problem happen before the CB has a chance to respond.
- They are large/heavy. The negative on this should be apparent.
- They introduce resistance in the circuit.
- Would be difficult to size it right. You want it to allow the high current surges that the motor will legitimately pull, yet blow if "bad" current is pulled. How is it to know when the current pulled is "ok" or a sign of a problem?
- CC has integrated in thermal shutdown, which is probably the easiest/best way to implement catastrophic shutdown. Trouble is, it sometimes doesn't react fast enough.
brushlessboy16
brushlessboy16's Avatar
04.22.2009, 08:04 PM
Originally Posted by 93firebird View Post
With this I think there needs to be a circuit breaker which protects the unit from too many amps and causing a fireball like mine did.
Thats irrelevant.
has nothing to do with a switch.
Finnster
KillaHurtz
Finnster's Avatar
04.22.2009, 09:06 PM
Maybe a sprinkler system instead lol
93firebird
04.22.2009, 09:15 PM
I was thinking of full on halon gas system for the full effect
What's_nitro?
Soldermaster Extraordinaire
What's_nitro?'s Avatar
04.22.2009, 09:30 PM
Just design a vacuum chamber into your R/C and put the MMM in it. If there is no O2 there can be no fire!
NoControl
NoControl's Avatar
04.22.2009, 10:10 PM
And with a vacuum the esc may stay cooloer, I mean look if you do a google for the contains they store Liquid Nitogen in.
What's_nitro?
04.22.2009, 10:14 PM
Actually the ESC would get hotter, faster because the only way it could cool down would be radiant heat (infrared). There would be no matter to allow conduction of heat via physical contact.
himalaya
himalaya's Avatar
04.23.2009, 12:07 AM
I dont't hate the switch, but just want it covered by a good dust condom, 'cause all my MMMs' switches were killed by dust.
....What a Blue Sky....
brushlessboy16
04.23.2009, 06:58 AM
Put it in a vat of silicone oil.
fan will be come an oil cooling pump
hemiblas
hemiblas's Avatar
04.23.2009, 07:42 AM
When I hook up my watt meter and turn the switch off the amp load is 0. Are you guys sure the ESC drains the battery with the switch off? Now switch on, it does measure a very small load enough to drain the battery. There has been a couple times when I take a tumble and the switch turns off. Made me a bit worried on my V3, but then I just check it and turn the switch on and everything is good again.
twisted8
04.24.2009, 12:23 AM
why not just take a little piece of lexan and make a lever that slides over once the switch is "on" and keeps it from moving. its an old school trick.
brushlessboy16
04.24.2009, 06:58 AM
Kind of defeats the purpose of a switch then..
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
04.24.2009, 07:23 AM
ive mannaged to foil the switches evil habbits
mount the switch on your car so that it is laying flat (on it's side) AND the switch moves horizontally to the cars body.
this works amazingly well...bacuase think about it...
the main G-force you get is gonna be from a nose on or a flat land....the only way the switch can turn off in this setup is if you land sideways hard on the wheels...
and all cars have a tenancy for the diff to stabilise it in hte air...so ive noticed that you rarely land on your side hard off a jump...
ive never had a switch turn off on me ever from doing this
  Send a message via MSN to shaunjohnson
ta_man
04.24.2009, 10:39 AM
I think the switch they should use is the type that comes with many radios for the receiver pack (like a Futaba Radio). It is much bigger than the current switch but is very sturdy and reliable.
Patrick
Patrick's Avatar
04.25.2009, 02:04 AM
You still use the switch normal, you just slide the piece of lexan out of the way when you want to turn it off.
