Superemaxx89
01.16.2006, 03:23 PM
So what do you recommend? Just two 3s1p packs?
Gustav
Gustav's Avatar
01.16.2006, 03:39 PM
Well yeah,but it's 'cause i'm allergic to paralleling.If you bought 4 3s1p packs it would cost the same,you still have the same no. of cells but your only running half of them at a time so you should actually get longer runtimes by not using energy carrying the others around.Those 4000mah cells are 12c constant (i think) so that's 48amps constant which may be enough but i'd like to hear other's opinions on this.If it's not then there's a reason to paralel but even so i'd rather go to a higher discharge cell like the polyquest XP 3700 16C/flightpower 3700 20C.http://www.duralitebatteries.com/batteries-esilver.html
for the extra $15 per pack.
Superemaxx89
01.16.2006, 04:05 PM
I'll also be selling two superbrain 959 chargers $65 for both.
I'm going to go with the 3s2p, rated at 96 amps, I think i'll need it.
coolhandcountry
coolhandcountry's Avatar
01.16.2006, 04:22 PM
10 xl on a 6s lipo sounds better than a 12 xl. But both would be a good motor. 12xl on 8s would rock.
Peace!
Country
Help support the
Rc-Monster
Buy here
Superemaxx89
01.16.2006, 04:28 PM
I like the 12xl. This truck will be HEAVY. 2 reciever packs, one to power the RX, the other to power the esc fans. 2 3s2p packs equels the weigh of 15 NIMH cells (which isn't that bad), RCalloys rear center cvd, gpm tran case (HEAVY), UM Gears (also heavy), reciever and rx battery holders (off a tmaxx), 8spy diffs, ue steel cvds, integ knuckles. The rest is stock, but this thing will be heavy: 13 pound range.
squeeforever
squeeforever's Avatar
01.16.2006, 07:53 PM
why not one lipo reciever pack at 7.4 volts with a high mah? im not sure but i dont think it would hurt the servo.
Superemaxx89
01.16.2006, 08:46 PM
i think 7.4 is pushing it...
squeeforever
01.16.2006, 10:21 PM
i know some of the hitec servos are capable.
Superemaxx89
01.16.2006, 11:56 PM
I'm talking mostly the reciever. But i'll be happy with 2 rx packs. I cannot believe i'm about to spend $500 on batts alone, then another $160 on a charger!
squeeforever
01.16.2006, 11:58 PM
i take it your getting the schulze?
Superemaxx89
01.17.2006, 01:20 AM
maxamps told me to buy two of the Hyperion EOS5i Chargers
squeeforever
01.17.2006, 01:57 PM
i would get the 7's. its worth the little extra money.
MetalMan
MetalMan's Avatar
01.17.2006, 09:39 PM
Is 2amps more with the ability to charge 11 more NiMh cells worth $50? They both do 5s Lipo.
