zeropointbug
Z-Pinch racer
zeropointbug's Avatar
05.21.2009, 08:42 PM
Ricky!
timaneli
05.22.2009, 06:05 AM
yes. i mean 13.2v at 4600mah.
is more then enough for small or regular tracks.
i run this cells with my hobbywing combo with 2350kv motor geared for 40mph.
is more then enough to smoke nitros if you know what i mean!!
i don´t think for a e-revo is needed more voltage and power then that, maybe more run time for packs!!
i run the car in this setup for 3 months with sucess without any thing break!!
the cells fit the compartments perfectly in size and is 4 cells for each pack wired in paralel and connect in series.
you are what you race!!
zeropointbug
Z-Pinch racer
05.22.2009, 10:26 PM
mah... 4s2p would be okay i guess, considering it's 2300kv motor (how big BTW?)
I have had my Revo since fall of 2007 I haven't broke anything either... except for suspension arm, my fault.
My Revo running 7s1p and 7s2p packs running 1512 Neu(1700kv) has plenty of power (~1300watts) and agility with the 1p pack... the 7s2p has noticeably more power(2500watts...theoretical) and punch but I don't like the feel of it compared to the 1p pack... too heavy and not as agile.
zeropointbug
Z-Pinch racer
05.27.2009, 08:08 PM
Well I made an 8s A123 pack and it doesn't work with the Quark... I plug it in and turn the switch, it makes an alarm beeping sound (obviously for over-voltage protection)
Well, I think I am going to get either some flightpower EON X30's, or the ThunderPower 40C packs... I am thinking more towards the TP packs however just because of the best voltage holding ability. I am sure they are both good choices.
I just need the E-revo chassis now...
