sikeston34m
sikeston34m's Avatar
08.26.2009, 11:00 PM
The gears are small just the the regular diff, set the slipper to your tatse and it'll last a while. You wanna use 6s with 1/10 scale diff,it's gonna give sooner or later ?
I was using one with nitro for a few months befor I decided to convert it, I checked the CD and gears were ok, but leaked dry. Leaking is problematic with the silicone gasket design. Sorry I can't be of more help..
Thanks Bondo. I appreciate it.
I just want to get this "pick list" of parts together.
My setup is going to use 4S actually.
A MMM ESC and a 36-70-2000kv Medusa. I may upgrade to a larger motor later. But first I have to get this setup to be reliable.
I'm not sure If I will like the handling changes the center diff brings, since I mainly bash. I may give it a try though.
PS.....I've been running the 1/8th scale RCM diffs. Kinda disappointed they didn't hold up longer
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.26.2009, 11:26 PM
My TRX CD in my nitro powered 3.3 Revo w/500,000 wt still diff out.
If you bash,considering staying with the tranny as is.
Murphy's Law- "If It Aint Broke, Don't Fix It ?
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
08.27.2009, 06:20 AM
Thanks MC
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
neweuser
neweuser's Avatar
08.28.2009, 06:36 PM
Originally Posted by sjcrss View Post
Thanks MC
From experience, sjcrss knows his diff well. It was cheap to make, and I would highly reccommend it. The stock diff is junk!! Also, since credit is being gave here, was it not my idea to put the 1/8 directly into the case dude? LOL
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
08.28.2009, 06:09 PM
really?
ok then in that case i'm gonna put this kyosho 500k to replace the std oil in the revo center diff and see if that makes it any better...
  Send a message via MSN to shaunjohnson
sjcrss
sjcrss's Avatar
08.28.2009, 09:17 PM
gotta bust my chops eh...it was YOUR idea...I just implemented it...lol, and figured the in' & outs on how to make it work...Thanks T
Bl E-REVO
Quark 125b
((2s2p)(4s)
simplechamp
simplechamp's Avatar
08.29.2009, 03:20 AM
So just to make sure we are clear: neweuser came up with the idea, mistercrash created it all, and sjcrss ripped it off and tried to take credit for everything? sounds about right
Anyway, just got the last required parts today for the Thunder Tiger hybrid version. Hopefully will start the build soon, so expect some questions all you guys who've already made one of these.
neweuser
neweuser's Avatar
08.29.2009, 05:39 PM
[QUOTE=simplechamp;316590]So just to make sure we are clear: neweuser came up with the idea, mistercrash created it all, and sjcrss ripped it off and tried to take credit for everything? sounds about right [QUOTE]
Delusions of Grandur right there nooby...if you peep sjcrss's sig, you can plainly see there the ideas. In fact, I wanted to stick a 1/8th diff in an FLM tranny case for years. Just never took the time to do it and Mike came out with the slipperential anyways, so there was no need for one.
neweuser
neweuser's Avatar
08.29.2009, 05:40 PM
[QUOTE=neweuser;316700]
Delusions of Grandur right there nooby...if you peep sjcrss's sig, you can plainly see there the ideas. In fact, I wanted to stick a 1/8th diff in an modded FLM tranny case for years. Just never took the time to do it and Mike came out with the slipperential anyways, so there was no need for one.
simplechamp
09.02.2009, 12:28 AM
[QUOTE=neweuser;316701]
It was a joke, hence the little winking icon.
sjcrss
sjcrss's Avatar
08.29.2009, 04:53 AM
LMAO, thats a good one....hehehehe.... Newe and I we talking and he had a idea to put a 1/8 scale diff in the erevo, but kinda like the original slipperential, I then decided to see if i could make one fit into the erevo tranny, and did some fitting ect. and came up with the design I used and supplied to MC, he made a great tutorial on how to make the diff...however MC did come up with some design tweeks of his own, that i will not take credit for, cause they were his idea's.... this about sums it up...
Bl E-REVO
Quark 125b
((2s2p)(4s)
sjcrss
sjcrss's Avatar
08.29.2009, 05:42 PM
thanks T, well i think enough about who did what or when...I can supply info as well as MC...... I think credit needs to go where credit is due....so here goes.....
Original Idea 1/ scale diff in FLM case...newe
1/8 scale diff in erevo tranny ( I made up theplans ect. and did all the test fitting ect.) ...sjcrss
shaft re-design's and other gear mods...ect plus new ideas for the cd design...MC
this being said everyone is getting credit where it is due.....
Bl E-REVO
Quark 125b
((2s2p)(4s)
neweuser
neweuser's Avatar
08.29.2009, 05:48 PM
IMO, who cares! lol It works!
simplechamp
09.03.2009, 04:18 PM
I just started making my center diff. Today I ground down the center spur gear. It was suggested to me to use a nut and bolt assembly to chuck the spur into a drill press, then use an angle grinder while the drill press rotated the spur. I didn't have an angle grinder, so what I did was chucked the spur/nut/bolt assembly into a hand drill and used that to spin the spur while I ground it down against a bench grinder. Probably took longer than using an angle grinder, but it worked out fine.
Not sure if I took off enough yet, but I was concerned about grinding too much off of the outer lip and making it too weak/brittle. Is this going to be a problem if I left the modified spur like this?
sjcrss
sjcrss's Avatar
09.03.2009, 04:40 PM
It looks ok to me, one thing i did, is I determined the cap overhang, per the gear mounted to it, but it looks good so far
Bl E-REVO
Quark 125b
((2s2p)(4s)
