Originally posted by Serum
Jackson, Sorry for the mechanical resistance story. we where crossposting.
Are you able to measure the voltage from the UBEC?
And what gearing are you running on your maxx?
Did you removed the BEC jumper from the 9918?
Doesn't explain why it did work, and it does not work now though..
And Yes Mike i agree on BEC problems from both of the controllers. I looked a bit misty, because of the crossposting.
With regard to mechanical resistance and binding. Am I over looking something? I am a rookie at this (3 months now) RC stuff so feel free to jump in and point me to another method.
I don't have a VOM but I could get one. It's too late to test it since it's already stripped off and waiting for new parts.
Gearing is 16/66 right now. I do also have 70t and 72t spurs to gear lower.
Yes, the BEC jumper from the 9918 was removed.
I don't expect to see the same problems again with the new BEC-less controller / motor. If I do then the only thing left is the UBEC. I didn't think it acted like that to me when this was happening so I didn't install an rx pack to test with. If it happens again, I'll put in the rx pack and return the UBEC for replacement.
All that said, I don't think it's the issue. It shouldn't get so hot as to melt off the heat shrink wrap IMHO. I could be wrong though. Mechanical binding maks a lot of sense, but I just can't find any.
The only other think I could come up with was the esc mount acting like a heat sink (via the motor mounting plate). This really seems an unlikely thing too, but I just don't know what else could make it that hot.
