12.04.2009, 09:59 PM
Originally Posted by HomeGrown View Post
just need a get rich quick scheme..lol..
dude, your name is homegrown. grow from home. $65 an 8 guy up here in MN.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
12.04.2009, 10:23 PM
1 word, "OUCH"
I guess it's 2 for 1 here then ?
J57ltr
12.04.2009, 10:55 PM
1 word, "OUCH"
You guys must be high paying that much
12.04.2009, 11:29 PM
i saw a study where the number one asked for invention was by housewives that wanted some machine to fold clothes.
HomeGrown
HomeGrown's Avatar
12.05.2009, 10:52 AM
1 word, "OUCH"
thats still steep lol
trust me ive thought bout it at $120 oz. up north and $50 to $70 here i can double my money for a 24 hour drive.. and if homegrown its al profit!!
BL Pede, Integy aluminum steering linkages, aluminum shock caps, RPM camber links.
Never Replace Always Upgrade!
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
12.05.2009, 02:19 AM
some of these are pretty good.. other not so.. and some completely impossible (females not bitching).. what about a solder gun that only heats when touched to solder? ive seen the "cold touch" one but that dont really work.. it dont get hot enough to do some things and it dont get cold very quickly they must have used a time lapse camera while doing that commercial.. i dunno maybe its to far out.. i just need a get rich quick scheme..lol..
you could be onto something there...
put a metered current through the solder wire, so when touched on the work surface, it shorts with a earth clamp and melts the solder. a lot like ARC welding.
  Send a message via MSN to shaunjohnson
12.05.2009, 11:17 AM
Gotta be careful with any soldering solution that uses current to melt. Current means voltage is present, and may be catastrophic for some electronic circuits.
I also have a few ideas, but I consider them to be "innovations" rather than "inventions". Innovations are, IMO, better ways to make something work using existing methods, or using something that exists in other applications.
12.04.2009, 10:31 PM
Solar powered flashlights?
talking bras?
family size diet pills?
Unsullied_Spy
Unsullied_Spy's Avatar
12.04.2009, 10:52 PM
Solar powered flashlights exist (I have one, somewhere )
You don't listen to who wears the bra, why would you listen to the bra itself?
Diet pills you're on to something. Promise perfect results with no side effects then when the lawsuits for kidney failure roll it you book it out of the country
HomeGrown
HomeGrown's Avatar
12.05.2009, 12:24 PM
ya Brian i've also thought of those innovations you speak of..lol i was thinkin making a hydrolic (battery operated) lift to lift the ramps of like back hoe trailors.. but then my boss said they have them already.. but what if i can make them for cheaper and of better quality using a different design?
12.05.2009, 01:56 PM
Get rich quick= find a stupid rich person whos had their appendix removed, and convince them to buy yours as a replacement.
I like to dream up cool new inventions, but as with most things in life its kind expensive to develop and patent the idea (unless you go on tv shows like 'Dragons den').
bigsteel
12.05.2009, 02:50 PM
for the longest time i wanted to make electromagnetic shocks and by controlling the current it would essentially make RC stability control, but the concept would work on even full size vehicles.--josh
12.05.2009, 03:35 PM
I believe they have that already in 1:1 cars, or at least the concept. And I think they even use the shock's motion to generate power - regenerative suspension. In R/C, the benefit to power/weight ratio would be prohibitive unless it was in a large 1/5 scale+.
12.05.2009, 04:22 PM
My audi has it... Electromagnetic suspension...
The shock oil has fine iron particles in it - it uses an electromagnet to create a field around the pistons - greater the charge the slower the oil will react and alter the handling...
lutach
lutach's Avatar
12.05.2009, 03:57 PM
Bose has something like this: http://www.bose.com/controller?event...suspension.jsp. I also remember a R/C guy making one for his vehicle.
