Thomas Porfert
Thomas Porfert's Avatar
03.04.2010, 04:50 PM
I wouldn't call it a case, it's still a label, but it is harder plastic. I would say it is more durable than the original style, but that's the only difference. Oh and the sides are open so you can see the foam core between the label and circuit board.
03.04.2010, 04:52 PM
So, kinda like thinner r/c body lexan (like from Trx RTRs)?
Thomas Porfert
03.04.2010, 06:04 PM
Kind of. It's a bit more flexible, a little bit thinner, and has a rough surface. It's very close to the plastic covers on Five Star notebooks; I know it's a weird reference, but it's the only thing I can think of off the top of my head.
03.04.2010, 06:08 PM
Gotcha! Still better than just the sticker label...
georgec
georgec's Avatar
03.04.2010, 09:58 PM
Thanks Thomas, Again I'm just happy to have the field link, so I store it carefully in my transmitter case. Much too important to me to just toss it in the old tool box!
Frost
03.06.2010, 01:19 PM
I just got my Field Link too.. I'm so happy that Castle came out with this product. It really helps me with ESC setting on the fly.
I'm wondering if Castle can fix a minor bug in the Field Link, whereby, when I'm setting Motor Type to Brushless, and then I single-click from from Motor Type to Motor Timing, the Motor Type setting (that I had just set) automatically goes to the next available setting (eg. from Brushless to Brushed Reversing).
Hope Castle will include Field Link firmware update into the Castle Link software.
Not a serious bug. I still like the Field Link very much. Thanks Castle
Joe Ford
Castle's Chaos Corner
Joe Ford's Avatar
03.06.2010, 09:48 PM
Email this to me please. joeford@castlecreations.com
Thanks Frost!
Joe Ford
Product Specialist
Frost
03.07.2010, 09:54 AM
Email sent.
(btw.. it also happens to Motor Timing parameter after single-click)
Hope there is a fix for it.
Nevertheless, the Field Link still rocks! I love it
Thomas Porfert
03.08.2010, 04:49 PM
Frost,
I just tried recreating this issue with a Sidewinder and a Mamba Max and was unable to recreate the problem. I was able to program it to brushless, tap the button once, and it went straight to timing. I scrolled back through and it kept it on brushless. I double checked on the Castle Link and it showed brushless as well.
I want to try to recreate this problem so we can show it to the engineers. Can you please fill in a few blanks so I can try to recreate the problem?
What controller are you trying to program?
What version of software is on the controller?
What version of software do you have on the computer?
Have you ever connected the Field Programmer to the computer?
Please let me know and we'll see if we can get to the bottom of this.
Thomas Porfert
Castle Tech Support
Frost
03.08.2010, 11:10 PM
Here are the answers to your questions:
- Mamba Monster Max (F310C)
- V1.24 (Beta)
- Castle Link version 3.251
- Yes. No problems encountered when using Castle Link software to set the MMM ESC via Field Link. The problem only happens when using Field Link powered by battery via MMM ESC.
J57ltr
03.08.2010, 11:24 PM
I had a weird thing happen when changing to a cutoff of 9V. Everything programmed fine, but when I went to use the truck the next day the motor just shuttered in both forward and reverse(like it was set for brushed).
The wires battery and motor got very hot in just a few seconds. I got the programmer out and checked the settings and when I went down to motor type it was set to brushed reverse. I changed it back to brushless and everything was fine. I was pretty sure it was user error.
Jeff
Joe Ford
Joe Ford's Avatar
03.07.2010, 12:09 PM
If you didn't put that in the email, shoot me another please if you don't mind. Hopefully we'll be able to get this resolved quickly for you guys.
Joe Ford
Product Specialist
simplechamp
simplechamp's Avatar
03.07.2010, 05:16 PM
Can any of the Castle guys give an update on when they expect the Field Links to be sent out to people who used the coupon that was included with the Mamba Max Pro?
Frost
03.07.2010, 09:37 PM
Ok Joe, already done that. Thanks
Thomas Porfert
03.08.2010, 04:54 PM
If you chose to upgrade to the field programmer for $10.00, we should be shipping those out shortly. If you can PM me your info, I can look it up and give you an update. If you only asked for the standard free link, we are currently working on some and they should be available soon as well.
Thomas Porfert
Castle Tech Support
