justchil
01.16.2011, 10:51 AM
I haven't even managed to break a stock set of diff's (I have some cheap aluminum bulks now) but I know as soon as I start running 6s things are going to break.
Even now... the real weak point of my E-Maxx is the chassis! I hit a telephone pole at <15mph and broke a chassis in half D:
OK I found all the hotbodies stuff that I would need. Check out this post: http://www.beatyourtruck.com/forum/s...l=1#post824097
Copied:
UE do, but all they use are Ofna Hyper diffs basically- look on ebay etc for some 'ofna differentials'. Hotbodies are getting hard to find these days for some strange reason, but they are just as good. Just add in the needed bearings & some 8x10x0.2mm shims...
However, because Im sofaking awesome, I found all the Hotbodies parts on Amain:
http://www.amainhobbies.com/product_...htning-Stadium x2
http://www.amainhobbies.com/product_...g-Buggy-Series x2
http://www.amainhobbies.com/product_...02mm-Washer-10 x1
http://www.amainhobbies.com/product_...el-bearings-10
You'll also need 4 of these:
http://www.rc-monster.com/proddetail...d=RCMdiffshaft
If you want to use the stock driveshafts or the traxxas cvds & drive cups ( or you can make your own by cutting the threaded part off of these: traxxas stub axles ).
You'll also need these driveshaft coupler with 8mm bore ( v2 ) if you want to use the stock center driveshafts, or pickup a couple 8mm drive cups such as these with an 8mm bore.
The only part I don't see is the 8mm bore v2 driveshaft coupler. I am running Traxxas Opti-drive cvd's/driveshafts so I will need to get some 8mm drive cups for the center shafts.
I'm going to do the rear diff first and document everything so maybe it will be helpful to someone else.
01.16.2011, 04:34 PM
UE uses ofna spider diffs in their TVS & Ultralite kits- you wont get much better than that really, but regular ofna buggy diffs or the HB lightning buggy diffs are near-as-dammit bullet proof regardless..
01.18.2011, 06:18 PM
Maybe, but the output cups on the diffs are a little shallow, so the cvds may popout if you dont screw the pillow balls in. Most guys tend to change the output shafts/ cups to something longer/ deeper, or use the rc-m output shafts to fit deeper traxxas drive cups. Mike is out of shafts at the moment, but you can make your own using traxxas part #5454 & cut off the threaded part.
mjosparky
Sparky
mjosparky's Avatar
01.18.2011, 10:44 PM
You could go with Revo drive cups. They fit and are just a little bit deeper.
Sparky
http://www3.towerhobbies.com/cgi-bin...?&I=LXTPP0&P=7
Sharpchuter 245
Dyna Wide Glide
RC toy
Got Brushes? NOT
RC toy's Avatar
01.19.2011, 08:34 AM
Oh, you mean those for extended rear wheel base arms?
01.20.2011, 12:11 PM
Yup, those be the ones.
