toby
toby's Avatar
03.19.2006, 09:51 AM
the "grub" screw on the dogbone holders for the center shafts are both sup[er tight and same with the pinion
rc18mt/blade cp
HotnCold
HotnCold's Avatar
im leaning towards slipper pegs - when its in the air you can get the tires to balloon - when on the ground no - are you sure that the pegs on the slipper are ok?
Hows that "Hope and Change" working out for Ya???
coolhandcountry
coolhandcountry's Avatar
03.19.2006, 10:35 AM
This is a problem I have incountered. If you put the truck on the floor can you turn the spur by hand with out truck moving? If so what turns and what don't. Check and make sure you did not shear the pegs on the pressure plate. If you did it will slip. It is not the slipper is bad but the pressure plates them selves.
Peace!
Country
Help support the
Rc-Monster
Buy here
toby
toby's Avatar
03.19.2006, 06:47 PM
guys guys guys....
i have been running the truck all damn day LOL. i dunn owhat the problem was. i took abart my ear end and opened the diff case and than put everything back together and it runs AMAZING. 7xl and 21020 on 14 cells is nuts. i cannot wait to drop 16 cells in it.
My motor seems to be geetting hot but it might be because it is not getting airflow because my speed control is ontop of it because i have no where to mount it yet. all the weight is on the front of the truck but i can still flip it on it's lid effortlessly.
I broke a gorillamaxx battery strap though. the nut ripped right through the strap. i went head on into wood. nothing happend. i was whipping through the wet field behind my house a WOT as well. this truck is the best!
rc18mt/blade cp
toby
toby's Avatar
03.19.2006, 07:09 PM
something just hapend guys. i was running it, and it just died. like seriously stopped running . i have NO idea what happend it just died. so i check my batteries and they are still pluged in and everything seemed fine. nothing was hot. any idae what that is?
rc18mt/blade cp
Superemaxx89
03.19.2006, 07:24 PM
loose connection?
toby
toby's Avatar
03.19.2006, 07:26 PM
what do you mean/ everything was the same. but it quit.... maybe it is those batteries?
rc18mt/blade cp
Sylvester
Sylvester's Avatar
03.19.2006, 07:55 PM
if you have a voltage meter you could check those batts voltages.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
HotnCold
HotnCold's Avatar
03.19.2006, 07:59 PM
How is the receiver - or the crystal - do you have another receiver/crystal to try it out - easy way to eliminate these 2 things.....
toby
toby's Avatar
03.19.2006, 08:15 PM
i guess i can check it out. Maybe i will upgrade the radio, which i am saving for an m11 with spektrum but dunno yet for sure.
rc18mt/blade cp
HotnCold
HotnCold's Avatar
03.19.2006, 09:05 PM
Worth a shot.... let us know what you find out....
squeeforever
squeeforever's Avatar
03.19.2006, 09:19 PM
you said "in the wet fields". did you see any smoke or smell a burnt smell from the controller?
toby
toby's Avatar
03.19.2006, 09:24 PM
no sorry, by wet i meant damp mud that i could walk on when my truck was flipped. like it wasn't soaked or anything
rc18mt/blade cp
squeeforever
03.19.2006, 09:30 PM
ok. were you running a reciever pack or ubec?
Sylvester
Sylvester's Avatar
03.19.2006, 09:33 PM
he doesnt have a ubec or reveiver pack squee.
Losi 8ight e
