snellemin
2 KiloWatt RACER
snellemin's Avatar
01.28.2011, 08:04 PM
It should do fine with a low rollout.
Through google I found the Viper 1/8 motor webpage. The rotor size is listed as 13.8mm.
6 KiloWatt A123 Racer
24s2p EVG SX 49.6mph Ebike.
simplechamp
simplechamp's Avatar
01.28.2011, 08:27 PM
Nice, looks like it will be completely user rebuildable like the 1/10 Vipers. Would be nice to have one motor and then be able to buy a different stator if you wanted higher/lower kv.
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.30.2011, 02:24 AM
Higher kv's would be nice too.
snellemin
2 KiloWatt RACER
snellemin's Avatar
01.31.2011, 04:58 PM
Novak also has the 1/8 motors coming. 8 and 8L versions, 1.5y and 1y
http://www.teamnovak.com/press_relea...c_8_Motors.pdf
02.01.2011, 06:39 PM
Took 'em long enough to make a real 1/8 motor- no mention of kv ratings though..
I see they are also making a compatible 1/8 esc ( again, very late into the game ), but limited to 4s? Hmm...
snellemin
2 KiloWatt RACER
snellemin's Avatar
02.01.2011, 06:42 PM
The 4s is the let down. I wonder if they will put gearing limits too.
fastbaja5b
fastbaja5b's Avatar
02.01.2011, 10:04 PM
I guess that explains why the SC8e has a Castle Combo, not the LRP Combo in there.
Say Less, Do More.
simplechamp
02.01.2011, 11:02 PM
Yeah, I would guess lots of burned up motors and speedos, and too much complaints and warranty claims. They did have a RTR (or maybe they called it "combo" version) of the SC8e with the LRP system for awhile, but it only lasted a short time before they discontinued it.
80931-25 — SC8e/SPX8/Vector 8 2500Kv *Discontinued*
80931-28 — SC8e/SPX8/Vector 8 2800Kv *Discontinued*
That said, I am going to try out the Vector 8 motor in my on-road GT, but it's a different application (small wheels, low rollout) than 1/8 SC, and I know how to gear a vehicle properly. Even then I'm unsure if the results will be acceptable. So I can imagine someone throwing in 6S with the 2800kv in the SC8 with stock gearing would be in for some big problems.
