07.20.2010, 04:36 PM
He may be referring to the field programming card...
Pdelcast
Pdelcast's Avatar
07.20.2010, 04:45 PM
AH! I misunderstood.
No, unfortunately -- the field link can't set torque control.
Patrick del Castillo
President, Principle Engineer
simplechamp
simplechamp's Avatar
07.20.2010, 06:35 PM
Perfect timing, just got my EagleTree today. First thing I'll do is test out the torque control and power limiting features.
Question: How does the max throttle limiting feature compare to say turning the throttle EPA up or down on your radio?
07.20.2010, 07:00 PM
Applying less than 100% EPA would simply like not applying the full range to the throttle trigger; so, 75% EPA would be like only going to 75% of the max travel of the trigger.
This release seems like it has potential. Although, since torque is a function of current, I don't know how the ESC can know how much current is being pulled unless it has a current sensor like the ICE line does. Speaking of this, wouldn't torque control be similar to current limiting in a way?
simplechamp
07.20.2010, 07:17 PM
Yeah I get how EPA works, but how does the max throttle limiter work? I just assumed it did the same thing as lowering EPA. So if you set the throttle limiter to 75%, is that accomplishing the same thing as turning the EPA down to 75% (providing you calibrated the ESC with EPA at 100%)? I guess with the throttle limiter you would still have the full range and resolution of your throttle trigger?
nuz69
nuz69's Avatar
07.20.2010, 07:24 PM
IMO the torque limiter is in fact a current limiter. Concerning the power limiter, if the power is too limitated i suspect the ESC to heat a little more than usual. That could explain why with this firmware the fan is always ON...
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
Pdelcast
Pdelcast's Avatar
07.20.2010, 08:10 PM
The torque limiter is not exactly a current limiter, but it works similarly (the difference being that the torque limiter isn't reactive -- in other words, it doesn't react to changes in current, it actively controls torque, which in effect controls current...) Make sense?
07.20.2010, 08:19 PM
So Patrick, how exactly does the torque limiter work then? If the answer is getting into the "trade secret" realm, I understand, but you've provided technical explanations for all the other features, and I just like to know how things work.
bryan
bryan's Avatar
07.20.2010, 08:55 PM
I'm also in the dark? Isnt this like using a battery with a lower discharge "C" rating ?
sikeston34m
sikeston34m's Avatar
07.20.2010, 09:34 PM
No, not exactly.
But it might enable you to use a battery with a lower C rating.
I'm sure this will serve to tame amperage spikes during acceleration.
I have a 12" 3 Blade Prop hooked up to serve as a fan as my desk.
Yeah, it's wicked when you turn it up, but is a nice breeze on low.
Powered by a Mamba Max Pro, it has kept me cool for hours on end.
I installed the update to my MMP, and it's going to be very interesting to play with.
The smallest number on the torque control scale ramps the speed up slowly, like climbing a hill.
I can see where dialing this control in, to your setup and track conditions, will definately give a race advantage. You can dial in the degree of controlability you need.
This will also serve to protect driveline parts.
It also makes me wonder if you could use a larger motor, gear a bit higher and still reach a higher level of overall efficiency?
Cooler Temps by taming amp spikes? I think so.
bryan
bryan's Avatar
07.20.2010, 09:45 PM
That makes sense.
Thanks James
FG101C
07.20.2010, 10:49 PM
Went back to v1.26 on the MMP and v1.24 on the MMM, both cars are perfect, smooth as glass, no cog and everything I want the esc to do.
I played with all the settings in I don't know how many combinations and always the same result. Alot of cog then lunging forward, if I kept the throttle at 1/4 it would run smooth (after the initial lunge) for about 5 seconds. Every five or so seconds it would lurch forward again.
I'll be waiting for v1.28, maybe everything will be good then, but currently with v1.26/v1.24 I have no complaints.
Stoomstrijkijze
07.21.2010, 03:39 PM
And if you load the default settings again?
ANGRY-ALIEN
ANGRY-ALIEN's Avatar
07.21.2010, 03:41 PM
I will try that later when I get home...
brushlessboy16
brushlessboy16's Avatar
07.21.2010, 09:41 PM
Yay! I had put the old-new sofware on my truck yesterday and went to run it today and it was dead as a doorknob. Got home and saw this thread and intalled the new-new software and it runs, no more paperweights :) thanks for the speedy fix castle creations.
