pinkpanda3310
pinkpanda3310's Avatar
10.30.2010, 09:18 PM
LST = roughly 18mm square , 26mm diagonally
ROUGHLY
Manne
10.31.2010, 05:24 AM
Thanks panda
And now the Bp meassures someone?
thzero
10.31.2010, 11:36 AM
18.5mm square, 25.75mm diagonally
Manne
10.31.2010, 12:49 PM
Thanks alot guys! That will do, it will work with some will
I wonīt do this right now, but I will post here when I get it done
Manne
12.04.2010, 07:43 AM
I have ordered some lst diffs now, and I have some savage diffs right here on the table...Just waiting for the diffs to drop in.
Manne
12.23.2010, 07:18 PM
Well, I didnīt have Bp diffs here, it was some savage x 4.6 diffs, they have a higher tooth count than the BP diffs butt since the BP diffs have bigger tooths I think the final size of the ringgear is similar, Itīs simply a much bigger gear than the gears that the lst diffs are using.
So... I simply shimmed and installed the Lst diffs with some steel dogbones and other goddies, Iīm running my slipper completly locked and after 20hours we are still going strong :).
And I didnīt have to remove much material from the bulkheads at all, where the material is removed isnīt were I use to snapp my bulkheads anyway.
Manne
01.03.2011, 06:34 AM
Just a small update.
The diffcup from the savage fits on the lst cup and vice versa, the only difference is that the lst cup is sligthly slightly shorter, maybe itīs a good idea for people that is stripping the intrenals on their fluxes to use a lst cup, and for the Lst owners that are stripping internals to use savage internals instead since they are a bit thicker and would make the gearmesh tighter.
I didnīt mount it all up tho, so Iīm not 100% sure that it will fit, but I thought it might be a good idea since you have a limited space to shim the internals on because of the pin that the gear sits on on the output.
DanteX
01.06.2011, 12:05 PM
@ Manne:
Can you please post a picture of the diff-case with the Savage internals.
I want to use the diff for a savage trophy truck build.
Thank you
Regards, Andreas
