Darren
12.02.2010, 12:32 AM
1A for 40 minutes isn't a full charge from dead. I would try charging at 2A. Power from the stock battery isn't incredible but it is decent. Also take into account that most of the videos you see, they will be using 2 or 3s lipos, the truck is still stock but it doesn't mean the battery is. Also yes, out of the box the slipper is loose, I had to tighten mine up.
I know, but comparing my truck to this video where he is using the included battery : http://www.youtube.com/watch?v=MbRAGuXmPZM, mine isnt close to that.
I know it's not a full charge aswell, but i'd expect even a half charge to give a good indication of the power in the system. My brushless cars of the past were just as quick at half charge pretty much, as they were at full charge.
I'll give it a proper going over tomorrow, and try get a snow video using the phone I get tomorrow when it arrives! :)
Darren
12.02.2010, 02:15 PM
Had it out today in the snow, and it suddenly started cogging, really badly. To the point where you almost need to stay on full throttle to avoid it. Batteries are fine (Using the standard packs), sometimes the steering servo -when turned slowly and not moving the truck- doesn't respond until you give a bit of throttle, even a single 'cog' to send some power through the truck. I tried changing the CH1 position on the reciever and the problem remains. I also re-linked the Tx/Rx, still the same problem.
Here is a video of what happens when I put two 6 cell packs in series and try to run the truck:
http://www.youtube.com/watch?v=Xt0y8Cx8lQM
Any thoughts?
Finnster
KillaHurtz
Finnster's Avatar
12.02.2010, 02:21 PM
To me it sounds like the battery is crap. It could be dropping to a low voltage and causing drop outs in the rx. Would explain the weak servo and low power output.
Are you sure you are running them in series? That's ~12-14V+
If that's true, you may have other problems...
Darren
12.02.2010, 02:23 PM
Yup, the video was done in series. I have tried a single pack and two in parallel, all with the same result.
Both batteries are pretty much fully charged.
Dj_Sparky
12.02.2010, 07:42 PM
Try disconnecting the servo, try another receiver and radio, and go over the wires to make sure its all connected tight and right.
josh9mille
josh9mille's Avatar
12.02.2010, 07:58 PM
Any thoughts?
It almost sounds like there is a pebble in the gears or something
Darren
12.02.2010, 08:38 PM
Checked everything just now, everything's connected fine. Tried disconnecting the servo and still had the same problem.
I don't think there is, everything's sealed and if you put it on a single 6 cell pack, the wheels will spin consistantly as long as you give it 60%+ throttle.
I'm starting to think that the ESC is at fault and I should just return it to get replaced under warranty? Also the front bulkheads have a few 'holes' in them. Like there has been bubbles in the plastic moulds , interesting.
E-Revonut
RC-Monster RC8T
E-Revonut's Avatar
12.03.2010, 12:38 AM
I had a "hole" in my front bulk too. I figured out what it was for though, just before I sold it I had to replace the front diff. There is a long screw that you access through that hole after you pull the suspension pin out
Darren
12.03.2010, 12:27 PM
Aah, that makes sense.
On the plus-side. I tried the revo again this morning, and its fine .
bruce750i
bruce750i's Avatar
12.03.2010, 12:58 PM
What did you do to fix it. Did you read the manual or was it some other last resort?
Darren
12.03.2010, 06:39 PM
Literally nothing. Turned it on and it worked. Could have been a tiny drop of water on a connector or something?
