Pdelcast
Pdelcast's Avatar
01.13.2011, 11:33 AM
Originally Posted by freddy View Post
Pdelcast, will there also be new rotors for the 1515 motor?
reason i ask is becouse one of mye old 2200kv motor prob need new bearings in near future(better sooner than later i guess) so just wonder if i should wait so i also can get the new redesignd rotor
thanks
(sorry for my grammar\spelling)
Don't expect anything in the real near future -- we are doing a lot of simulations, testing, and experimentation here to find the best possible solution. The tooling is very expensive, so we don't want to have to do it more than once. :)
Thanx!
Patrick del Castillo
President, Principle Engineer
01.14.2011, 06:47 PM
Here's a good question- I heard the traxxas 1515 motors have a rear endbell with a hole in it so you can see the shaft and bearing, is it possible to use the same design on the regular motors so that the rear bearing can be poked out if it needs to be replaced?
I havent had any issues myself ( touch wood ), but by all accounts if the rear bearing fails then its more or less impossible to remove- a sticker over the hole wouldnt be such a bad thing in my eyes if it makes maintenance easier. ABEC 3 bearings would be cool too vs the standard ABEC 1 affairs that are currently used still unless they've been changed recently..
Long live my/the MMM V1
Pdelcast
Pdelcast's Avatar
01.15.2011, 01:20 AM
Hi Neil,
The early 1515s were like that - - and we had a lot of complaints from people that sand was getting past the sticker and into the bearing. Or they would remove the sticker, and then dust/sand would get into the bearing. Or the sticker would fall off, and dust/sand would get into the bearing. So we just sealed it -- it's actually more expensive to manufacture the way it is now.
The rear bearing fails very rarely, because it is under very little stress, and we haven't had any complaints about it since we covered the rear end. :)
Oh- and to replace the rear bearing, you drill a small hole in the end-bell to drive out the bearing...
01.15.2011, 11:33 AM
Fair enough then
I do have one gripe though; the fins on my 1518s have rather sharp edges where they've been machined to expose the bare metal underneath the green anodizing, not normally a problem unless you are sliding the motor on an emaxx mount ( to set the mesh ) and grip it a bit too tight- needs a light rub with a emery cloth or something just to take the edge off, so to speak.
Pdelcast
Pdelcast's Avatar
01.15.2011, 01:50 PM
Fair enough then
Yeah, and the HPI grenade style motors (we call it "the lacerator") are even worse ... but they love it!
I'll talk to China about putting a .2mm round on the corners of the fins. I don't know how much more it will cost, but I'll ask.
ta_man
01.15.2011, 10:52 PM
Here's a second opinion: I like the edges just the way they are.
01.16.2011, 04:28 PM
Masochist^.
It doesnt bother me so much now I know how to handle the motor, Im just thinking about some moronic parent trying to sue castle because their precious spawn hurt their fingers whilst working on the truck.
You could just insert a piece of paper into the box that says 'handle motor with caution, sharp corners are present- please grip motor with gloves or a piece of cloth to prevent damage to your finger tips'. That way they cant moan about it..
ksb51rl
02.10.2011, 12:51 AM
I got a 2833 sitting on my desk right now. It's an eight pole, 200kV, 12kW monster. About 20K RPM on 100V.
Got an application???
Lithium-battery-powered go karts? How would it do on 48V?
http://www.polepositionraceway.com/go-karts/
BIG-block
02.10.2011, 11:50 AM
Any idea on the ETA of the repair kits for the 1518, 1520 and the 1717? Would like to have spares in the tool box.
j.f.s
04.06.2011, 03:51 AM
Bumping this thread as I'm eager to get a repair kit for my 1518. I'm prone to wrecking my stuff and having spare parts beforehand is always a good idea! :)
nuz69
nuz69's Avatar
04.06.2011, 04:33 AM
You can buy a 1515 repair kit, the bearings are the same (good luck for breaking them ) and you can't really broke the rotor unless you demagnet it.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
j.f.s
04.06.2011, 04:39 AM
Ah, thanks for the info nuz69!
It's mainly the bearings I'm after. I'm convinced I'll manage to ruin them knowing the luck I usually have with my stuff.
slimthelineman
slimthelineman's Avatar
04.06.2011, 01:15 PM
I heard at rcx that repair kits were coming for the neu 14xx series four pole motors. Anyone heard or know when we might see these? I got a 1406-4600kv that's dyin to be used in my lcg slash.
molak
04.08.2011, 01:04 AM
niklass
04.08.2011, 07:01 AM
I'm wondering about the size of the bearings in the 1512 motor, I'd like to have some spare bearings in my toolbox.
Mostly because I have a very good bearing shop nearby and it would be nice not to pay shipping for something I can buy locally.
